PLZ help ...need help ASAP
Old Feb 13, 2005 | 01:24 PM
MaximaRacer_95's Avatar
My car has been acting wierd lately...wen ever i let go of my brake the car dosent move at all until i press the accelerator n car is on D on a flat suface...next thing happens is tht it doent go over 2000 rpm wen im floorin it or doent not go on two second gear n i chked it noe MAF sensor tt causin this, but wen i put the car on parking n press the accelerator it is normal(rpm increasin as i press the accel.)but i had this TPS Code showin wen i chked the ECU codes but it has been there for a long time now.
Ne body noe wats goin on...
Old Feb 13, 2005 | 01:59 PM
njmaxseltd's Avatar
What language is that?
Old Feb 13, 2005 | 02:09 PM
my car has automatic transmission..n now wen i tried changing the first two gears manully it wasnt smooth n it skips the second gear n goes onto third..ne clue wats happening?
Old Feb 13, 2005 | 02:11 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
if you cant go past 2000rpm then replace your MAF now.
Old Feb 13, 2005 | 02:16 PM
now thts not the problem ne more its the gears not changin rite the way they suppose to..n this jus started to happen this morning..its not goin on to the second gear at all..n something is rong with first.
Old Feb 13, 2005 | 02:27 PM
A Flood99's Avatar
you need to put it in D and see if you go through 1st, 2nd, 3rd, and 4th
i'm not a big fan of manually shifting an automatic
Old Feb 13, 2005 | 02:31 PM
i tried doin tht too but the same thing happens...as soon as i put it on D the car should move rite? it doent until i press the accelerator to 1500 rpm n it not going smooth as rpm increase..it skips thorugh second gear goes directly to third.
Old Feb 13, 2005 | 02:38 PM
A Flood99's Avatar
no, it sounds like you are starting in third gear if you have to get it to 1.5K before it moves
if you were in first gear the car would roll at idle ~600rpm
have you pulled any codes? car could be in safe mode, hopefully tranny isn't shot
Old Feb 13, 2005 | 02:41 PM
yea i pulled the TPS(throttlebody positioning sensor) but its been thier for a long time now...i think the car is starting in third gear it doesnt move wen its on idle at 600.
Old Feb 13, 2005 | 02:44 PM
A Flood99's Avatar
disconnect your battery and re-connect and see if that corrects anything
it may be your TPS finally catching up to you....if its not able to tell how open your throttlebody is that would definitely affect engine performance...and the tranny could just be in 3rd gear as a preventative measure
never run into this problem.....this is just my reasoning
Old Feb 13, 2005 | 03:04 PM
jackiss2888's Avatar
is your parking brake on?
Old Feb 13, 2005 | 03:21 PM
i jus came bac from chkin ecu codes after disconnecting batteries...n these were the results
1104(Improper Shifting to Second Gear (Automatic Transmission))
1103(Improper Shifting to First Gear (A/T))
0302(EGR System Hi/Low Flow)
0504(Automatic Transmission Control Unit Signal to ECU)
wat do i do now.. ne suggestions
Old Feb 13, 2005 | 03:52 PM
njmaxseltd's Avatar
Still can't figure out what language this guy speaks.
Old Feb 13, 2005 | 04:01 PM
these r the codes that ECU is showing now
Old Feb 13, 2005 | 04:39 PM
96white's Avatar
Did you go to school
Please use spell check atleast.
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
