Diff. Whinning
Old Feb 14, 2005 | 09:12 AM
nismo2ner's Avatar
down with Bing
Diff. Whinning
It sounds like my differential is whinning is that what it is?? Its a higher whine when i excelerate...... And What can I do about it and info like that??
Old Feb 14, 2005 | 09:22 AM
tallica62's Avatar
i am having the possible same problem. Does urs usually happen at low speeds/1st gear? That is typical. If it is ur diff. bearings, that sucks. A common prob. with gen 4 are the bearings go way too soon and can be up to $1000+ to fix. There is tons of info in the FAQ sticky and i have even put a few posts up yesterday concerning that. Def. read the stickies...they will answer ur questions
Old Feb 14, 2005 | 09:26 AM
nismo2ner's Avatar
down with Bing
aright thanks mine happens when ever there is a strain so if im a little gas is given it whines a bit but ill check out the stickys
Thanks again
Old Feb 14, 2005 | 09:28 AM
tallica62's Avatar
nice car by the way...
ever think of puttin clear corners in? I think id look real nice for ya
Old Feb 14, 2005 | 09:35 AM
nismo2ner's Avatar
down with Bing
Thanks That pic is old and it became winter since i put clear corners in and a custom grill and AE headlights n stuff i just have not got around to taking a new pic since all of that lol
Is there any thing i can do other than replacing all of the barings and shimming it right.... Can i put in a 6 Speed Maxima Tranny??
Otherwise im going to tackle the problem when spring hits I think ill Rip Her apart myself and do it then i can put in my new flywheel i have a ACT Clutch from Stillen and i had my flywheel lightend a bit when it was out.... but i have a New Lightend Flywheel so i can put that in when i have everything apart
Old Feb 14, 2005 | 10:27 AM
MDeezy's Avatar
replacing bearing a shimming it if I'm not wrong is the source of the problem.
I've heard 6 speed tranny isnt worth it, and some say our 5th gen trannies are stronger a pull better. just what I have been hearing. . .
Old Feb 14, 2005 | 10:50 AM
nismo2ner's Avatar
down with Bing
aright kool kool thanks for all the info
Old Feb 17, 2005 | 02:08 PM
nismo2ner's Avatar
down with Bing
Is there a write up on how to do it or the details of doing it.... and the parts i need to get and about how much they cost... im goign to be doing this in may so i want to gather as much info as i can before then
Old Feb 17, 2005 | 04:44 PM
Kinger402's Avatar
Mine whines as your describing just in first gear. If i am at low speed in second it doesnt do it at all. Just in first gear. I was just told that first gear is always a noisier gear and that i should not worry about it. Any opinions?
mark w chrzanow
Feb 23, 2003 05:11 PM
cui
Jul 17, 2002 08:44 AM
Simon S
Jul 15, 2002 04:47 AM
