I'm trying to put an i30 auto-dimming mirrow in my max -- HELP!!!
Old Feb 14, 2005 | 09:35 AM
erty67's Avatar
Decal Specialist
OK, I've heard that if your maxima has a homelink visor then it should be wired for an auto-dimming mirror. I got the mirror today, but I can not find a harness to connect it into. Can anyone help me??? I am clueless on how to hook this thing up.
Old Feb 14, 2005 | 09:49 AM
HomerMAC's Avatar
Donating i30 Owner
.... ahh u need a power source.. .. thats it... like the mirror has positive and neg. so. find a source.. liek the lighter... or a source thats always on.. incase u want the mirror to remember the setting u left it on.. auto or day after u turn ur car of...
Old Feb 14, 2005 | 10:07 AM
erty67's Avatar
Decal Specialist
The mirror has a connector with 4 wires going to it. how do I know what's what? I was really hoping I could just plug it in. DOH!
Old Feb 14, 2005 | 12:46 PM
Max96GLE's Avatar
Take a picture of the wires, maybe the someone can help you a bit. How much you pay for it? I'm interested in something with direction and temperature build in. Ebay here I come...
Old Feb 14, 2005 | 08:44 PM
HomerMAC's Avatar
Donating i30 Owner
hmm well theres + - for the actualy mechanisim... that dims the mirror.. now if im not mistaken the exra +- is jsut here for connecting something else i presume.. becuase someone else did this on teh max and they didnt connect hte second set.. ust two..
Old Feb 14, 2005 | 09:31 PM
lefty
From what I remmeber when I installed mine is I had two wires. One hooked up to the power sorce tapped into the cigarette lighter and then the other GROUNDED to my Ebrake. The autodim has nothing to do with the wires.
The last wire I had was for my temperature gauage. Took like 15 min to do the whole install.
Old Feb 14, 2005 | 09:36 PM
pavelsmax's Avatar
lefty where did you get your mirror from is it out of an i30... does it mount like our oem mirror
Old Feb 14, 2005 | 09:46 PM
erty67's Avatar
Decal Specialist
gimme more details....gimme gimme I have 4 wires on a plug
Old Feb 14, 2005 | 10:39 PM
Frank Fontaine's Avatar
I think there are many aftermarket ones available, and i don't see how they would be any different, positive and negative, and then any other functions like temp or compass......I just don't like a wire hanging out. When I sat in the 2k5 there was an ugly wire running to the mirror. That should be hidden like in the MB and BMW if you ask me, but then again, what does Nissan care what I think?
generic install
Good luck!
Old Feb 15, 2005 | 05:52 AM
EdL97SE's Avatar
Isn't there a ground and power source that you can tap by the sunroof motor?
Old Feb 15, 2005 | 08:49 AM
Kevin's Avatar
i know what your talkign about the 4 wires, i have mine in but not connected, need to know what wires i can tap to where. Lefty, what color were the wirres from the mirror you connected to the lighter and the ground?
Old Feb 15, 2005 | 04:01 PM
bill927's Avatar
I got the schematic from a dealer. There were different diagrams for different years. I got mine from a 96 I-30. I honestly forgot what I did but I think I only used hot and ground somehow. One was going to the instrument cluster, don't remember why, and I think one went to the switch for the lights or something. I got around all that. I'll see if I can find the schematic. If you call the dealer and know someone there they can tell you what wire goes where but you will need to know the year model the mirror came from. People may say I'm nuts but I had a 35 year master tech print the diagrams. They do differ by year. Each diagram was different and they listed the model year and which car.
Old Feb 15, 2005 | 04:08 PM
Kevin's Avatar
any chance you can scan tha schematic? is it something thats in hte FSM? I think mine was from a 97.
Old Feb 15, 2005 | 04:18 PM
Kevin's Avatar
I got this through some old emails and PM's from a fellow org member
1. Black - Ground
2. Red with Yellow Stripe - Find this on the back of the speedo
3. Red with Blue Stripe - Find this on the back of the speedo
4. Green with Blue Stripe - I think this is just an accessory wire and can be wired to any power source that is on when your ignition is turned on.
I might be wrong on color codes but i found 3 of the above four on the speedo meter including BLACK. One of them that i couldnt find went to an ignition power source. Let me know if you need any more help.
Credit: max99se and Max4speed
Old Feb 15, 2005 | 05:11 PM
seth99gxe's Avatar
Ok, heres the deal with the four wire connector.. I installed an auto dimming mirror in my max a while back and there isnt any connector pre-wired in the maxima for an autodimming mirror.. I got the wiring diagram from an I-30 to figure out where each wire was supposed to be hooked up..
*black goes to ground
*red/yellow wire goes to the illumination control switch on the dash under the gauge cluster
*red/blue goes to the light switch fuse #18 7.5A in the fuse panel which is by the hood release, the wire coming from this fuse should be a blue/yellow wire
*green/blue goes to any 12v switched on/start source.
I used splice terminals that you put the factory wire in one side and your lead wire in the other and as you crimp the connector it punctures both wires creating your circuit, this way I didnt have to cut any factory wiring. You can find these types of splice caps at any local hardware store or home improvement warehouse.
If you dont care about the buttons lighting up and or dimming when you turn the headlights on then you dont have to worry about the red/yellow or red/blue wires, you can just hook up the ground wire to a good ground and the green/blue to a 12v source and it should work. Hope this information helps if you have any questions let me know..
Seth
Old Feb 15, 2005 | 07:38 PM
erty67's Avatar
Decal Specialist
you guys rock! thanks
bill927's Avatar
I do believe Seth is right. I remember that one went to the dimmer. The gauge cluster thing is possible, I was told the same thing but it would be a pain. I just wired mine so the auto and day switch are bright all the time and hard wired it to the light. It's on (mirror always has power) all the time and no issues as of yet. Been hard wired (hot) for over 6 months and I only drive my car on weekends. I have a company car.
Old Feb 15, 2005 | 08:11 PM
Jepht20's Avatar
Custom User Title...
goodluck ed!
i've had one sitting in a box for a year now and can't find the base plastic cover piece where it connects to the car. what a tease...
Old Feb 15, 2005 | 08:19 PM
Kevin's Avatar
hhmmm, i wonder if i could tap into the sunroof switch or something
Old Feb 15, 2005 | 10:10 PM
Lumberg™'s Avatar
on this site too damn much
hey guys, do you think this mirror would work? i want one with auto-dimming and compass. you think this would be an easy install?? do you guys have and links to places other than this one that you know intall and work good??
http://cgi.ebay.com/ebaymotors/ws/eB...category=33699
Old Apr 4, 2005 | 12:14 PM
erty67's Avatar
Decal Specialist
finally got it installed...and hooked up!!!
Old Apr 4, 2005 | 12:54 PM
ptatohed's Avatar
Licensed to Spell
Is that your 3rd or 4th gen erty?
Old Apr 4, 2005 | 12:58 PM
Kevin's Avatar
sweet....so what did you hook up where? I've had mine in my car for 2+ years not connected, its about time i hook it up.
Old Apr 4, 2005 | 06:07 PM
erty67's Avatar
Decal Specialist
it's in the 4th gen. I hooked up the green/blue and red/yellow to a switched 12V source and black to ground. I just tapped off my volt gauge on my a-pillar
Old Apr 5, 2005 | 07:59 AM
ptatohed's Avatar
Licensed to Spell
So the I30 mirror is still ceiling mounted, right? I have a mirror sitting at home that cost me ~$200 that has map lights, auto dim, compass and outside temp. Call me crazy but I have not installed it because I don't want a fricken button glued to my windshield.
Old Apr 5, 2005 | 08:12 AM
erty67's Avatar
Decal Specialist
Yup, I used the same three screw that hold that stock maxima mirror.
Old Apr 5, 2005 | 08:35 AM
ptatohed's Avatar
Licensed to Spell
Cool, maybe I'll get around to doing mine soon. You inspired me. In fact, I have to! I have a tint appointment for the 15th and I plan on doing a windshield strip. So the only thing the I30 mirror does is automatically dim? Any other features? No offense but I don't think I could care any less about the auto-dim feature. I never even flick my day/night stick right now. The last thing I want is the car doing it for me. Even though my mirror is technically an auto-dim with other features, it's the other features that sold me.
Old Apr 5, 2005 | 09:29 AM
erty67's Avatar
Decal Specialist
yea, the I30 mirror just auto-dims. I mainly did it for the "i30 upgrade", opposed to the want for auto-dim. I'm the same way as far as flick it manuallly. I must say though, it's a lot nicer than i expected. I love this thing at night. Glad I could be an inspiration!
soloist3
Sep 2, 2015 12:59 PM
Justin Kroll
Sep 2, 2015 11:06 AM
evonder73
Sep 1, 2015 02:21 PM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
