P1446 Code
Old Feb 14, 2005 | 05:33 PM
JetBlackMax83's Avatar
P1446 Code
Got the CEL had autozone pull the code for me P1446 evap emmissions the diog said but the ecu decoder on the org says undefined any body have any clue? the guy at auto zone said mybe the gas cap or small exhaust leak does this sound right?
Old Feb 15, 2005 | 07:52 AM
BUMP Anyone?..
Old Feb 15, 2005 | 09:33 AM
njmaxseltd's Avatar
According to the Haynes shop manual, P1446 is defined as EVAP canister vent control valve closed.
I suggest you remove the vent control valve and clean it up. It's located right next to the canister just behind the left rear wheel. It's most likely full of debri and stuck in the closed position.
Should be an easy fix.
Old Feb 15, 2005 | 03:53 PM
yup checked it out evap cannister thanks NJMax anybody else have to change this cannister on the org?? just want a heads up on how hard it is to change yourself ? thanks in advance
Old Feb 15, 2005 | 04:18 PM
wayman's Avatar
I got the same code a few weeks ago. Luckily the valve in question is really accessible (didn't even need to jack the car up to reach it).
I took out the old one, cleaned off the air openings and all electrical leads. I checked for obstructions in the air tubes and holes and found none. I threw on some di-electric grease on the electrical connection and reattached everything. I cleared my CEL a few times but it came back on almost immediately each time with the same code. At that point I just replaced the valve (got one from the dealership for less than $100). Once installed the CEL went away.
Good luck.
Old Feb 15, 2005 | 04:31 PM
Thanks alot im gunna screw around with it this weekend
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
