check engine light problem
Old Feb 15, 2005 | 04:59 AM
maximariceboi's Avatar
As I was driving my 99 5spd...my check engine light blinks on 2nd/3rd gear going over 4000-4500 rpm before shifting but goes away after like 30sec-1 min..does anyone have any idea in why it comes on like that? thanks
Old Feb 15, 2005 | 05:04 AM
njmaxseltd's Avatar
A flashing CEL under load incidates a misfire.
Old Feb 15, 2005 | 06:09 AM
Smaynor2934's Avatar
is there a check engine light and a service engine soon light, cause im gettin the annoying serive engine soon light on the bottom right, tried the ecu thing, didnt work? help im stupid
Old Feb 15, 2005 | 06:16 AM
thanks i ll check on that later today after school
Old Feb 15, 2005 | 06:17 AM
oh, you swap the ecu..damn.i was planning to..not sure why its on..heh
Old Feb 15, 2005 | 06:42 AM
A Flood99's Avatar
gotta love our 99 coilpacks
Old Feb 15, 2005 | 04:35 PM
ok so i drove to my dads shop and the light was blinking again and stopped... i scanned the codes and showed knock sensor and cylinder #3 misfire...shouldnt the light be on if its the knock sensor?..happened to my other one before...light was on...anyways so yea..i was doing other tests with the OTC computer and was checking the other sensors..bank 2 was like 99.2...that didnt look right so i checked on the other maxima..same thing so i guess thats fine? the idle was pretty low...around 620-650rpm compared to the other one which was 710-740..there is a misfire i guess...where sould i start? car has 85,700 miles and its a 99..
Old Feb 15, 2005 | 04:56 PM
fadeaway's Avatar
Go Hokies!!
Anyone know why I was experiencing this same problem a few months ago, but during the past couple months it doesn't happen anymore?
I currently have 141,000 miles on my 99. At 105,000 miles (previous owner), my "ignition coil pack #4" was replaced, along with some new sparkies.
Thanks.
Old Feb 15, 2005 | 05:35 PM
njmaxseltd's Avatar
Replace the coil pack on cylinder #3.
The knock sensor will not set the CEL.
The knock sensor code you got with the misfire code could be considered a ghost code. Replace the #3 coil pack and clear the error codes. You should be fine after that, but check after a week or so for the knock sensor code. If it's still there, replace the knock sensor.
Old Feb 16, 2005 | 06:33 AM
ok..thanks again
Old Feb 16, 2005 | 06:56 AM
Viking155's Avatar
I am having this problem too. It says knock sensor circuit mal. How sure are you it could be the cylinder #3? While back I got random misfire, which does not mean anything to me. Any other ideas greatly appreciated. Thanks.
Old Feb 16, 2005 | 08:19 PM
mine says the same thing for the knock sensor..but CEL didnt come on...when i scanned it, 2 codes popped up...the knock sensor and misfire on cylinder #3..has ur CEL ever flash for like 30 seconds while driving?
Old Mar 26, 2005 | 01:16 AM
Viking155's Avatar
Replace coil pack on cylinder #3, I just did. That is why your cel flashes, mine did that too.
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
