Belt NOISE!
Old Feb 15, 2005 | 04:45 PM
maxima2fly's Avatar
Belt NOISE!
My belt is a ***** dont STOP SQUEEKING! could it be my tensioner is too tight ? please help i tried wb 40 still doesnt work.
Old Feb 15, 2005 | 04:51 PM
|Bijan|'s Avatar
UCF Lexus
please
You sprayed WD-40 on your belt?
Old Feb 15, 2005 | 04:52 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
when does it squeal/squeak? cold? warm? have you recently changed the belts?
whatever you do, DO NOT use WD-40 or any other belt lubricant b/c your belt will one day fly off w/o you knowing it.
Old Feb 15, 2005 | 04:59 PM
maxima2fly's Avatar
When it got cold it started squeeling,now its warm temp and its still doing it.
Old Feb 15, 2005 | 05:41 PM
joeeey's Avatar
Are you sure that the 2 belts are tight enuf? Sound like the belt is loose and not too tight. If your sure it's tight then remove the Alt, A/c belt to make sure that it is coming from that belt and not the Pwr Steering belt. If the squeeling is gone after removing the alt a/c belt spin the tensioner pulley for alt a/c check for noise. Then you may want to REMOVE the tensioner pully and soak it in WD 40. The pulley only never use it on a belt.
Old Feb 15, 2005 | 06:26 PM
konak85's Avatar
Let me give you some advice. DON't mess around witht he belt tensioner too much. Believe me, i know. The tensioner is very sensitive you can easily strip the bolt. Your belts are probably worn. Just get them replaced.
Old Feb 15, 2005 | 06:29 PM
Crockpot's Avatar
tensioner bolt sensitive??? yeh maybe if you dont loosen your pully bolt first...
believe me, you don't know
Old Feb 15, 2005 | 07:22 PM
thekenone's Avatar
or like mine you might need to replace the main wheel. i can't think of the name for some reason. my belt had the same symptons. the replacement was $40 and a junk yard. i hope that isn't the prob but if it is it not that hard. but you better have an air gun and a lot of pb blaster.
Old Feb 15, 2005 | 08:46 PM
bnasty3's Avatar
my car does the same thing but only when I have the heater on. It started doing it when Helena MT hit -40 F last month. but if I let it warm up and then click on the heat it doesn't do it
Old Feb 16, 2005 | 05:06 AM
maxima2fly's Avatar
I had them replace liek 3 months ago so am guessing its loose,because it sounds like wobbling noise.
Old Feb 16, 2005 | 06:05 AM
Zipp028's Avatar
sounds like i might have the same kind of problem. Its when i start my car it makes this crazy squealing noise and sounds like it get louder as you rev the engine but then it dies off after a few seconds. Its a pretty embarrasing noise. This just started happening during this winter. My other max a problem like this with the heater never found out what it was tho. (i never really tried either)
Old Feb 16, 2005 | 06:20 AM
MassMaxima97's Avatar
So what would be the correct procedure to replace the belts??
Old Feb 16, 2005 | 08:46 AM
alpicone's Avatar
The sqeaky belts could also be from s/t dripping on it like maybe oil or coolant. You can check if it is sqeaking from this by cleaning up the belt. The easiest way to do it is take some toothpaste, and smear it on the inside of the belt in a few places (with the engine OFF). The abrasiveness of the toothpaste will clean it up right away, plus your engine will smell nice and minty. This is an old school trick that some old timer taught me.
Old Feb 16, 2005 | 09:13 AM
ronin22357's Avatar
my belt(s) started squeaking on start up too. it hasnt done this in past winters. maybe its time for new ones? too cold out to work on it right now
Old Feb 16, 2005 | 09:26 AM
Chickan's Avatar
My belts have started squeeking as well, but mostly only when its raining, and when its cold in the morning. I tried replacing my belts last weekend but I couldn't loosen the nut on the main pulley, it would just spin the pulley without the belt moving I might end up paying a stealership to do it...
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
