bogging problems?
bogging problems?
I've had this problem for about a month or so. Everytime I take the car off the line (just normal driving), it would require me ride the clutch until the car catches and starts going or else the car would bog, before I could get the car going fine w/o even using the gas, but when I do that now, the car bogs and sometimes almosts stalls. I think I might be needing a new clutch maybe not, but also when I shift gears the RPMS drop, then go up then the car bogs again, this bothers me a lot because it requires riding the clutch. Hopefully someone can help and its not my clutch. My max has 106,500 miles now, I think on the original clutch. I'm thinking most likely a new clutch.
not understanding your symptoms too well... the only time the car bogged was when id drive sorta hard, after 3k rpms, it woudl bog. the RPM would go up 400 rpm, drop down and then go back up. turned out i needed a new clutch.
HerpDerp1919
Sep 29, 2015 02:02 PM
