Tranny Troubles please read
Old Feb 16, 2005 | 12:06 PM
Dagger969's Avatar
Tranny Troubles I know someone has had this problem
Whenever I shift gears I can hear a clunking noise. The noise only happens when I'm rolling >=2mph. When I stop it no longer makes noise when shifting. If i give it a lot of gas real fast or get off of it real fast you can hear the clunking noise again. I checked all the shifting linkage up to the tranny and its all looking good. I have a lift, and when I put my car up on it all of the parts, that could make the noise, look pretty good. It could be just me but I think it started when I replaced the passenger side CV joint.
Anyone have any suggestions? This is driving me completely crazy. Anyone with just a guess, feel free to post. Im beginning to think its in my tranny.
Old Feb 16, 2005 | 12:31 PM
Blue96Max's Avatar
could be your poilt bearing,throw-out bearing in your clutch or sycros in the tranny. (Not 2 sure if i spelled that right)
Old Feb 16, 2005 | 07:48 PM
Dagger969's Avatar
I hadn't thought about the pilot bearing, a possiblity. It doesnt squeel or feel rough though. And my only thing with the syncros is that it makes the clunk noise between almost all the gears if I get on it fast enough and let off it fast enough. I dont drive it like that but....you get the picture. Does yours make that noise at all or do you hear nothing when shifting?
One last thing.....It makes the noise when shifting even if I dont let the clutch out. Just the shifting motion alone from second to third will make the noise. Thanks for your help!
BUMP
EDIT: Isn't there supposed to be some sort of tranny bearing problem in the 95&96's?
Old Feb 16, 2005 | 10:25 PM
Dagger969's Avatar
BUMP....come on, someone has had this problem, cant be just me.
Old Feb 16, 2005 | 10:37 PM
Blue96Max's Avatar
yea 95-96 trannys suck so i hear, and yes i have the same problem its just when i let go the gas it sounds like something is grinding but when i step on the clutch it stops, i had my car checked out and i was told i need a new tranny becuz of syncros.
Old Feb 16, 2005 | 10:54 PM
PAREDLINE's Avatar
what happens when you let go of the clutch and the car is NOT moving? Might be your throw out bearing
Old Feb 16, 2005 | 11:23 PM
Blue96Max's Avatar
idk does it idle still but doesnt move? Becuz if it does and your idle picks up more but you still going same speed, your tranny is slipping
Old Feb 16, 2005 | 11:39 PM
tedo007's Avatar
faster than you think
i have the same problem in my 2k1 but i jus deal with it i dont really care about it lol
Old Feb 16, 2005 | 11:48 PM
Blue96Max's Avatar
thats what i did and now my tranny cracked, so everytime i get an oil change i add gear fulid.
Old Feb 17, 2005 | 06:29 AM
bluevr6's Avatar
Check motor and trans mounts. Sounds like trans is moving around when on / off gas.
Peace,
Kevin
Old Feb 17, 2005 | 09:19 AM
Dagger969's Avatar
Thanks for all the help. Its not a grinding noise, just a clanking. I thought it was the motor mounts and\or tranny mounts, so I replaced them. Still does it. I get the same clanking noise when shifting whether I engage the clutch or not. So say im in second, I let off the clutch shift from second to third(it makes loud clanking noise) I let the clutch out and give it gas(makes loud clanking noise again). It has to be some sort of shifting linkage inside the tranny, I dont want to take it to Nissan but I almost feel as if I have to. Im so broke lol.
Old Feb 17, 2005 | 07:36 PM
Dagger969's Avatar
B U M P
Old Feb 18, 2005 | 05:52 AM
njmaxseltd's Avatar
Time to tare down the tranny, there is somethng not right inside it.
Old Feb 18, 2005 | 06:53 AM
Dagger969's Avatar
anyone sell kits to rebuild them? If so, what do they run?
mclasser
22
Nov 12, 2020 01:58 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
zmcneely13
Sep 26, 2015 02:26 PM
