Getting New Motor Mounts
Old Feb 17, 2005 | 09:56 AM
hacim105's Avatar
What would be the best way to go regardless of price?
1. Place Racing
2. Energy Suspension inserts
3. OEM motor mounts
4. other
Old Feb 17, 2005 | 10:38 AM
Ceasars Chariot's Avatar
Old Maxima Legend
http://www.ceasarschariot.com/links.html scroll down to motor mounts at the bottom, a few links to threads touching on place racing and energy suspension MM
Old Feb 17, 2005 | 11:25 AM
nismos14's Avatar
§è~® f®ÈÄk
place racing seems to be the most rough, with one person even having his melt, however it may have just been a defective one. I just recieved my ES motor mounts (oem mounts with the es already pressed into them) I am very very anxious to get them installed but that probably won't get done for at least 2 - 3 weeks oh well
Old Feb 17, 2005 | 12:38 PM
Flava_24/7's Avatar
Boosted Panda
Ask StephenMax to make you some
Old Feb 17, 2005 | 02:28 PM
Kta920's Avatar
anyone put 'em in yourself? I was about to buy some before i put in the turbo,and was wondering how hard it'd be?
Old Feb 17, 2005 | 03:54 PM
SPiG's Avatar
SomePsychoGuy
You can take the brackets off the car but you would need a really good hydraulic press to do everything yourself. Otherwise you need to bring the brackets to a shop.
PR is no longer made.
I recently installed ES motor mounts. I love them. A very soft vibrate at idle, you won't really notice it unless you look for it. If you have a rough idle then you will notice it though. Traction is much improved. Mine were blown and I think they were worth every penny.
Old Feb 18, 2005 | 10:02 AM
hacim105's Avatar
Has anyone filled their own with Polyurethene? If so, how do they feel and do they work well?
Old Feb 18, 2005 | 10:28 AM
Flava_24/7's Avatar
Boosted Panda
StephenMax has and he makes them from time to time and sells them.
I have a set installed and can honestly say, they rule.
Ive gone through two sets of motor mounts.
The first set were replaced with OEM. When they died, StephenMax made me the poly items. The feel so much better. The car feels so much more solid. Take offs are firmer and the car to me feels more responsive. I may have noticed such a huge difference being that mine were completly toast prior to the poly. ones.
Old Feb 18, 2005 | 10:58 AM
nismos14's Avatar
§è~® f®ÈÄk
i have the es ones installed as well, just got them in today as a matter of fact. I must say the hard 1-2 shift yeilds ALOT more useable traction, the car just grabs the gear and sticks to the road no wheel spin like with the stock crap mounts
Old Feb 18, 2005 | 11:20 AM
Old Maxima Legend
spig where did you buy yours online and how much for the install > ?
Old Feb 18, 2005 | 11:32 AM
SPiG's Avatar
SomePsychoGuy
Well frosty bought them for me through the Cattman intro deal. You can get them through there or for cheaper or the same price at www.suspension.com/nissancars.htm They are great and I have gotten other poly urethane stuff from them.
The install was a bit more than I had hoped. I didn't shop around enough and I was in a hurry and I got a local shop that I knew would do it (known for being a quality shop that does performance stuff but can be pricey) and they charged me $100 to press them in. It is still cheaper than OEM or PR ones with install but you can find shops that will do both for $50-80. To get the whole thing done normally costs more. They quoted me something like $250 or something crazy.
Old Feb 18, 2005 | 12:47 PM
hacim105's Avatar
how hard is the job to do yourself?
Old Feb 18, 2005 | 01:13 PM
1FSTMAX's Avatar
i got the es motor mount inserts.. and i love them.. Wheel hop is drastically reduced... The intallation was a breeze, to like 20 minutes to install these motor mounts.
Old Feb 18, 2005 | 02:17 PM
maxihari77SE96's Avatar
Who is StephenMax and how do we contact him?
SO, first I have to buy new motor mounts from ... OEM, for example and fill the with poly... and then install them, or can i just use the mounts from my car?
Sorry if stupid question.
thx
Old Feb 18, 2005 | 02:33 PM
hacim105's Avatar
thx
The motor mounts on your car should be fine unless the housing is cracked.
1fstmax how did you install motormounts in 20 minutes? All the shops say it takes like 7 hours.
Old Feb 18, 2005 | 03:43 PM
1FSTMAX's Avatar
hahhahaha wtf? I used air tools.. so that helped alot..
Old Feb 18, 2005 | 04:41 PM
SPiG's Avatar
SomePsychoGuy
Yeah air tools would help a lot. It is not horribly hard.
http://forums.maxima.org/showthread.php?t=366665
Post 18 has a "write up" but full of good info
also http://forums.maxima.org/showthread.php?t=316784
Old Feb 18, 2005 | 06:32 PM
Flava_24/7's Avatar
Boosted Panda
thx
Here..... http://forums.maxima.org/showthread.php?t=341853
Old Feb 19, 2005 | 08:10 AM
nismology's Avatar
Installation is easy. Raise the car up on jack stands, support the engine from the top, remove the motor mount through bolts, remove the crossmember, remove old mounts from x-member, bolt new ones on, then do the opposite of removal.
Old Feb 19, 2005 | 02:21 PM
hacim105's Avatar
Are you guys only replacing the front and rear mounts? How come not the left and right mounts?
Old Feb 19, 2005 | 03:56 PM
nismos14's Avatar
§è~® f®ÈÄk
the front and rear are the ones that effect traction, i think the left and right mounts are just there for supporting the engine, and stability.
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
