son-of-a-b!tchin nissan doors
Old Feb 17, 2005 | 10:15 AM
RicoSuave98's Avatar
my doors are so hard to close. am i alone on this? i cant even explain how people have tried to close my doors and they go half shut. wtf is the prob? i even put some wd40 in the hinges and it helped a little, but it's still stiff. and its not even that they're sticking. its all 4 doors. so what the hell.
Old Feb 17, 2005 | 10:33 AM
Armelius's Avatar
Probably because you are using WD40 and not silicone.
Old Feb 17, 2005 | 10:37 AM
JamesNH's Avatar
the door isnt hitting a fender or other metal is it? If its not then what i would do is lube up the doors with the wd40 and more the door back and forth the get the wd40 in. I was told that the doors close hard over time because of the lack of use.
Old Feb 17, 2005 | 10:44 AM
s0ber's Avatar
on the silicone
Old Feb 17, 2005 | 11:02 AM
MrRogerStatus's Avatar
VQ Disciple
Yea my rear right door does that, and screches real loud when closing fast. Already have plans to silicon it up. Cause WD40 does not work, well atleast it didn't for me.
Old Feb 17, 2005 | 11:05 AM
MaxKlinger's Avatar
I call the right rear door on my car the "man-door" because girls can't get it shut. One of my friends has a '94 Maxima GXE and the same door is exactly the same way on his car, too. I've tried working white lithium grease in there but it didn't do a whole lot. No screeching noises though.
aspec0002's Avatar
silicone only. WD40 is not a proper lubricant for something like that. Its main purpose is a Water Displacer, hence the WD-40. use silicone and see what that does for ya.
Old Feb 17, 2005 | 11:21 AM
nismos14's Avatar
§è~® f®ÈÄk
life some weights
Old Feb 17, 2005 | 01:37 PM
what kind of silicon am i looking for? its not hitting a fender or anything, and my driver door does it too, so i don't think its lack of use
Old Feb 17, 2005 | 02:11 PM
Armani
i put in silicone in my rear door a lot of times. That didn't help. I guess the previous owner did not open the rear door often enough. What really helped is simply grease. You have to grease it up, open and close 50 times and you will see, problem will be gone guaranteed!
Old Feb 17, 2005 | 02:15 PM
def will try this. grease makes more sense than sillicon. thanks armani
Old Feb 17, 2005 | 02:16 PM
ChristheNite
There is some part that you can replace from the 97+ maxima's - its relatively cheap and i guess the problem with our doors (yes, i have a "man door" too) is caused by the plastic slide that everyone keeps siliconing/wd-40'ing. Have someone do a search, i posted a thread on it a while ago....
trungg86
Sep 4, 2015 04:58 AM
Justin Kroll
Sep 2, 2015 11:06 AM
coasterswim
Sep 2, 2015 07:43 AM
Hailstatejig
Sep 2, 2015 06:52 AM
