It starts, it dies
Old Feb 17, 2005 | 08:20 PM
4x4Max's Avatar
It starts, it dies
My car hasnt been started in 2 days and its somewhat cold here, but i dont think its to the point of the engine freezing. When i first start the car, the rmps jump up to about 1.7k, and then jump down, the car chokes and dies. Tried it a few times with the same result. Then i just gave it a little gas on startup and it was fine. Idled at 1500 for a few minutes, then went down to 700-750. I turned it off, and started again. Rpms jumped up to 1700, went down, car choked, but then picked up rpms. My question is this: what could have caused the car dying over and over? My guess is it was cold, but ive never had trouble with a car not starting because its been in the cold for only 2 days.
Old Feb 17, 2005 | 08:48 PM
2 Da Max's Avatar
check your vacume lines, if not clean your tb, if not then ill think of more things
2 Da Max's Avatar
or it could be your coolant temperature sensor, or your ecu screw if not set properly
Old Feb 17, 2005 | 08:52 PM
4x4Max's Avatar
parents gave money for this car, so not allowed to screw with it(touch the engine). I'll check the vacum lines tommorow though, but i dont think i'll be able to clean the throttle body.
Old Feb 17, 2005 | 09:00 PM
Nismo3112's Avatar
Custom User Title
1)Engine coolant temp sensor
2)Clean TB, IACV
Old Feb 17, 2005 | 09:41 PM
kasemodz's Avatar
wut r vacumm lines? r those the iacv vavle? can someone post a pic plz?
Old Feb 18, 2005 | 07:38 AM
4x4Max's Avatar
Not sure where they are, but im just going to check all the lines because i have time. If i go to autozone for them to scan my ecu, will it tell if i need a new coolant temp sensor? If so, how much is it, and installation.
Old Feb 18, 2005 | 09:20 AM
2 Da Max's Avatar
sensor is like what 16 dollars the most? i got mine for 8. Its not that hard to change. btw how many miles do you hve? i would STRONGLY recommend cleaning out your tb.
Old Feb 18, 2005 | 09:55 AM
4x4Max's Avatar
i have 69,000 miles. Shouldnt sensors go at around 100,000?
shilov
Feb 19, 2024 09:40 PM
sctludwig
Sep 1, 2022 01:32 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
