JWT ecu question
Old Feb 18, 2005 | 11:14 AM
cardana24's Avatar
Blown
JWT ecu question
Will a JWT ecu out of a auto 96 maxima work in a 98 manual maxima? If so then will it throw codes? Anyone with insight please post. Thanks.
-Carson
Old Feb 18, 2005 | 11:15 AM
1FSTMAX's Avatar
it should work, but you'll get a crap load of codes, none which should affect performance tho..
Old Feb 18, 2005 | 11:16 AM
Ceasars Chariot's Avatar
Old Maxima Legend
will it work ? im pretty sure but not certain
will it throw codes ? it should
Old Feb 18, 2005 | 11:18 AM
SPiG's Avatar
SomePsychoGuy
Well it will most likely throw codes for the O2 sensor and the other things different between a 96 and a 98. Normally it would throw codes for the tranny but I am not sure if JWT could make it not throw them and I think they don't always send you the same ECU anyway. You can always take out the bulb or put a switch for the CEL wire. I do know that a manual car will run with an auto ECU. It will not work the other way around however.
Old Feb 18, 2005 | 11:31 AM
cardana24's Avatar
Blown
will another JWT ecu work better on a 98? or is a 96 auto ecu as good as I can get (other than the 96 M/T)
Old Feb 18, 2005 | 11:34 AM
deezo's Avatar
Just be aware that the O2 sensor code is thrown because of a difference in voltage from 96 to 97/98 models.
t6378tp
Sep 29, 2018 04:27 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
