Higher wattage fogs, will they crack lens?
Old Feb 18, 2005 | 08:12 PM
Rick James's Avatar
I will be getting yellow bulbs for my stock fogs.
Is the higher wattage that much a concern?
Old Feb 18, 2005 | 08:22 PM
Ladzio's Avatar
Yes it is. You are very likely to have them cracked when highter wattage bulb heats up the glass. Then in wet rainy weather you drive into a pudle and splash fogs with cold water, causing glass to crack.
Old Feb 18, 2005 | 08:27 PM
Rick James's Avatar
So i shouldnt mess with the narva rally golds rated at 85 watts?
are the piaa ion fogs any good?
Old Feb 18, 2005 | 09:49 PM
Ladzio's Avatar
Yes, highwer wattage bulbs are generally no recommended. Try finding something like 55 or 65 Wt
Old Feb 18, 2005 | 11:59 PM
Nismo98's Avatar
Get HID's and forget about fogs.
Andrei
Old Feb 19, 2005 | 12:13 AM
Nick7455's Avatar
I used higher a long time ago and both sides cracked....=(
Old Feb 19, 2005 | 06:57 AM
makavelisk's Avatar
I used to have 110 watts and mine basically exploded on a cold rainy day. The narva golds that I had were fine, but they run hot as hell.
Old Feb 19, 2005 | 12:44 PM
CKOTuHA's Avatar
They have Narva Rally Golds 55watts. Just get those.
Old Feb 19, 2005 | 01:49 PM
Rick James's Avatar
where do you get 55 watt Narva rally gold from?
On suvlights.com they only have 85 watt.
Old Feb 19, 2005 | 02:00 PM
CKOTuHA's Avatar
I heard that they have 55 watt ones there too. Try calling them or something
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
