cefiro wiring
Old Feb 18, 2005 | 08:36 PM
A Flood99's Avatar
cefiro wiring
anyone who has done H4 wiring, do you have any tips?
also wondering about the corner 1157 bulb splice job
Old Feb 19, 2005 | 04:17 PM
A Flood99's Avatar
bump......just wanting to know how to wire these H4 cefiros from my 9004 harness
also i'd like to know the same for my corners
Old Feb 19, 2005 | 04:52 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
i will check this on my car and will post the way i wired it up tomorrow. I ended up using a 95-96 harness on my 98 and wired the three wires so low filament would be on while the lights were on. The high filament I wired to the flashing corner, so when i turned it would light up brighter and be a secondary turn signal. but you can do what you want.
Old Feb 19, 2005 | 09:52 PM
A Flood99's Avatar
thanks slimer, seems there are 3 wires running into the stock harness so it shouldn't be too bad lining them up on the H4 harness
but the corner light's stock harness has two wires while the cefiro corner harness has 3 spots
also, is your above post talking about how you wired the other bulb in the main headlight housing
sorry, i've got em fitting really well just realizing there's three bulbs
Old Feb 20, 2005 | 08:36 AM
slimer's Avatar
do you have the harness for the corner light?
also the little city light that is in the headlight housing you can wire to the same spot.
i had to use the stock harness (where the bulb fits into) and modify it to fit the cefiro housing. actually, i used a 95-96 because i wanted to use the hi-lo filament.
do you have pics of your set-up?
if you cant host them, you can send them to belikelucy@aol.com
ps, i wont be able to look under my hood until at least 5 o'clock, im at work and its hailing outside. dont want to do it until i get in my garage.
Steve
Old Feb 20, 2005 | 09:41 AM
A Flood99's Avatar
this is what i'm working with.....i don't have a harness for the corner light but it has spots for three wires
i'm pretty clueless on how to wire up the corner and city light at this point
however the H4 headlight shouldn't be too bad since the stock harness has three wires and the H4 does too
Old Feb 20, 2005 | 03:31 PM
slimer's Avatar
you have to take your stock corner and cut it to fit. then you wont have to rewire anything.
for the headlight, i will be home soon.
Old Feb 20, 2005 | 03:37 PM
4DRSpeed's Avatar
Project Ruby......
Can you get a H4 plug n play harness of some kind? I am going to be installing my Cefiros sometimes soon as well.
Old Feb 20, 2005 | 03:51 PM
slimer's Avatar
there is a harness, but you have to cut yours. i double checked a chilton's service manual wiring diagram before i did anything, but i can read those easily.
if you need any help when you wire it up, just email me.
a flood, did you look at the write-up for the installation?
Old Feb 20, 2005 | 05:23 PM
A Flood99's Avatar
yeah, i got mine in and they're looking good
i'm waiting til tomorrow to wire them up, so no rush looking at yours
that does make sense just to custom do my stock corner harness to fit....too bad the lights are already on
Old Feb 20, 2005 | 05:24 PM
A Flood99's Avatar
and also 4DRSPEED, the install is not exactly the easiest thing i've done
Old Feb 21, 2005 | 11:03 AM
slimer's Avatar
it does take a little modding. did you put them in so you can take them out easily?
with the supercharger, i needed something that could come out easily.
Old Feb 21, 2005 | 11:39 AM
A Flood99's Avatar
oh yeah i have them in there and they'll come out in a snap
the install just took a little longer than i though; probably because i was too picky about fitment......but its true the longer you spend trimming and fitting, the better it looks
Old Feb 21, 2005 | 12:38 PM
slimer's Avatar
yes, the more **** you are, the better it looks.
Old Feb 21, 2005 | 12:42 PM
4DRSpeed's Avatar
Project Ruby......
Wiring everything wasn't too bad or anything. What would you say the most difficult part is? I am going to be going by the how-to writeup.
Old Feb 21, 2005 | 04:17 PM
A Flood99's Avatar
The hardest step definitely is getting your weather stripping to appear "nice" in the gaps.....so you just go back and forth trying new things
but i have them in, wired, and looking good...thanks slimer for dealing with me
Old Feb 21, 2005 | 07:47 PM
slimer's Avatar
A_Flood. I honestly was the third person on this board to have it done, after angie and mattel. Its good to be able to help people
Looking at it towards the firewall, the colors of the driver's side is black (left) green (top) yellow (right).
sorry it took me so long. i have worked 2 12-14 hr days in a row.
Old Feb 21, 2005 | 07:57 PM
A Flood99's Avatar
that's how i've got them
much thanks for the help
Old Feb 21, 2005 | 08:04 PM
slimer's Avatar
no prob. they look great. i like the beam pattern of the h4 so much.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
