creating slack around Water Pump / Timing Chain
Old Feb 19, 2005 | 09:17 AM
vstrt's Avatar
Ok, I got the timing chain tensioner out. Now, how do I create slack in the timing chain so that I can get the water pump out?
The "How To" said to turn the crank shaft. What does that mean and where is the crankshaft to turn?
Old Feb 19, 2005 | 09:24 AM
nismology's Avatar
Instead of creating 2 threads for the same thing reply to the other one that you started; which i replied to BTW.
Old Feb 19, 2005 | 09:56 AM
vstrt's Avatar
Actually, your advice about the allen key was incorrect. I got the tensioner out, but it had nothing to do with a pivot bolt.
This question has nothing to do with the tensioner. I'm wanting to create slack in the chain by turning the crankshaft, but I don't know how to do that. The tensioner is out of the way, I just need to know how to turn the crank shaft to remove tension from around the water pump.
Old Feb 19, 2005 | 10:26 AM
njmaxseltd's Avatar
Put a socket wrench on the bolt and turn it slightly to create slack in the timing chain so you can remove the pump. You can access the bolt from inside the right front fender. You'll need to remove a small section of the inner splash shield.
Old Feb 19, 2005 | 10:37 AM
konak85's Avatar
Get a haynes manual.
Old Feb 19, 2005 | 02:14 PM
nismology's Avatar
I thought you were removing the whole tensioner arm/chain guide assembly. My bad.
maxinout93
Oct 27, 2015 01:29 PM
Alberto10mg
Aug 25, 2015 12:54 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
