HELP! Wiring Bi-Xenon Projectors
Old Feb 19, 2005 | 12:54 PM
bkzsleepy's Avatar
I put bi-xenon projectors into my headlights and I need help on how to wire them. Do I connect them to high-beam wire?
Thank you!
Old Feb 19, 2005 | 01:38 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
what type of bulb is it? d2s? 9004? or h4? either way your going to need a harness or splicing will be needed. bi-xenon(both low beam and high beam) your going to need to wire both wires, they both share the same ground get a haynes manual it ill tell you what wire is what..
Old Feb 19, 2005 | 07:29 PM
bkzsleepy's Avatar
it's a d2r bulb. i know im suppose to use d2s for projectors but d2rs came with the projectors.
Old Feb 19, 2005 | 08:13 PM
nupe500's Avatar
Jedi Knight
You need to get familiar with www.hidplanet.com and radio shack. You need a DIODE in order to wire it properly. I believe the correct # for that is 1004 (crap I forget now) Regardless, the info you need is on the site above.
Old Feb 19, 2005 | 08:29 PM
gto400no1's Avatar
i used a 1N4005 i believe.
Old Feb 19, 2005 | 10:11 PM
bkzsleepy's Avatar
thanks you.
Old Feb 20, 2005 | 06:48 AM
bkzsleepy's Avatar
i just bought the diode, now how do i wire it? thanks in advance for your help guys.
Old Feb 22, 2005 | 01:09 PM
nupe500's Avatar
Jedi Knight
did you go to the site I referenced? You do have to do a little research, this will not just fall on your lap
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
