Spark Plug Boot stuck on plug! Need Help!
Old Feb 20, 2005 | 02:42 PM
Hades's Avatar
I was changing my sparks plugs last night and everything was going smooth till I got to the last one. When I pulled the coil pack out the boot did not come with it! The boot is still on the plug. Has any one encoutered this? Any ideas how to get it out?
Old Feb 20, 2005 | 02:49 PM
MDeezy's Avatar
so the bottom part of the coil pack broke and is stuck in therE?
Old Feb 20, 2005 | 02:52 PM
DAVE Sz's Avatar
Hooooooonda.....
That's what he said, no need to repeat it. It's not broken, the adhesive just finally let go. This happened to my friend twice. First time I used so rubber cement, let it set and pulled it out. Second time, well, he still has the old plug in there. Did you bother to try super glue or some other strong adhesive or did you just run to the comp as soon as it happened?
Old Feb 20, 2005 | 03:07 PM
Terran's Avatar
This is in the faqs...I believe it suggests crazy/superglue.
Old Feb 20, 2005 | 03:43 PM
njmaxseltd's Avatar
Use crazy glue, just put a few drops on the tip of the stem, put it back onto the stuck boot down in the spark plug hole.
Go have a beer
When you come back the boot will come up when you pull the coil pack.
Old Feb 21, 2005 | 11:15 AM
Goran's Avatar
yea, thats what happened to me once. I just used crazy glue, let it sit for few minutes and it came out easy.
Old Feb 21, 2005 | 11:19 AM
imports_only1's Avatar
Happened to me twice. I went to Sears hardware store and bought a long needle-nose plier and took it out with ease. After that, I went back and returned the plier.
Old Feb 21, 2005 | 11:41 AM
Ladzio's Avatar
Originally Posted by imports_only1
... After that, I went back and returned the plier.
Talking about ethical customers...
Old Feb 21, 2005 | 04:19 PM
Hades's Avatar
I went and bought some crazy glue, threw it on, had a beer, came back and pulled it out..PERFECT! Thanks for the help!!!
Old Feb 21, 2005 | 05:45 PM
DAVE Sz's Avatar
Hooooooonda.....
good job, glad it worked for you.
Old Feb 21, 2005 | 07:18 PM
izzydig's Avatar
Bah, you patient people.
I've bought two junkyard coil packs for just the stems and boot. I was too impatient and ended up ripping the damn boot out (either using needle nose pliers, failing with the super glue trick, or a jig).
I superglue the stems to the boot now.
Old Feb 21, 2005 | 10:31 PM
Zach95SE's Avatar
That **** happened to me and I couldn't get it out with any glue. So finally I used one of those pickle grabber nose picker things to get it out.
Old Feb 22, 2005 | 09:16 AM
BlackCat's Avatar
RIP '98 Maxima SE
I made myself a tool out of a coat hanger. I just made a loop at one end so that it'll grip the boot.
Old Feb 22, 2005 | 03:30 PM
maximusgee's Avatar
the spark plug boot got stuck on the plug in my car too, and I had to replace mine. I used crazy glue on another one that got stuck.
Old Feb 22, 2005 | 03:34 PM
SkoorbMax's Avatar
Holy hell, a real use for crazy glue? I've used that stuff on various things in the past and it's been consistently garbage. I still am annoyed to think of the pic of the guy hanging wit the hardhat and one drop of that junk. It's about as sticky as shampoo, and holds no better either.
Well, I'm done ranting. Apparently in this case it does work.
Old Feb 22, 2005 | 05:27 PM
RichMax's Avatar
Boosted like Snipes tax refund
I didn't have the benefit of the faq, so I panicked. I used a bent-up wire hanger to claw at and eventually remove the boot.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
