tranny went...
Old Feb 20, 2005 | 03:06 PM
Zipp028's Avatar
tranny went...
Driving back to work today and my 1st and 2nd gear ( 5spd) seamed to wine. Minutes later i find my self rolling down the hill and my car will not go into gear. The stick itself went in but it just was not engaging. I pulled over and walked to work. After work I swing by my car to grab a few things from it and see that it is leaking a lot of tranny fluid. Well now this has been my 2nd problem with 5pds maximas both 96's, i can vouch for the maxima trannys as being sh*t. I am assuming i am going to need a new/rebuilt tranny, I might as well replace the clutch and flywheel while i am at it, any opinions?
Old Feb 20, 2005 | 03:14 PM
Bobo's Avatar
How many miles on the car? Has the clutch been replaced before? Check out the master & slave cylinder.
Old Feb 20, 2005 | 04:07 PM
MDeezy's Avatar
Could be your throw out bearing
Old Feb 20, 2005 | 07:28 PM
MaxsRock323's Avatar
You should prob get it looked at before u start buggin out about your tranny. Things will work out. Best of luck to u, and your car is hot.
Old Feb 20, 2005 | 08:41 PM
Zipp028's Avatar
rmurdoch - My care has about 135K on, I bought it with 103, and i have not replaced the clutch yet so i dont know when the last time it was replaced.
MDeezy - I was thinking it was my throw out bearing because i have heard that the throwout bearing seams to make that wineing noise. but would that cause it to leak my tranny fluid out when it broke down?
MaxsRock323 - Yeah I am getting a tow truck to pick it up tomorrow, it just bums me out ya know. Your from cheyney? do i know you? i live in cheyney also! Have u seen my car?
Old Feb 20, 2005 | 08:46 PM
fade's Avatar
tranny
i live in nyc , does nayone know any places where i can get a tranny rebuilt or replaced cause i ahd the same problem, i thought it was the throwout bearing too and when i had the tranny pulled, it turns out i need to replace both. any help would be appreciated
Old Feb 20, 2005 | 11:40 PM
dayglo's Avatar
ive had a whining noise in 1st and 2nd for a while. just realy small though. i didnt know it could be a problem though. lately the stick has fealt a bit more notchy...did you notice anything like that before you broke down? notchy shifting, wierd feel in general?
Old Feb 21, 2005 | 06:39 AM
Zipp028's Avatar
I had the whining noise in 1st gear for awhile, then suddenly i heard it in second, and i knew right away wow this cant be good, and then it sounded like my tranny started making weird clicking noises. and i just knew that this sh*t is going to go and it did. (the 2nd gear whining and clicking of the trans started in the same 5 min ride to work) I am hoping it might be a hose that just leaked all the tranny fluid out but it prob isnt.
Well i am going snowboarding today and tomorrow i figure with the luck i am having that i should go and try to have some fun.
Old Feb 21, 2005 | 09:23 AM
MDeezy's Avatar
the whinning is a tranny issue not a clutch issue. The throw out Bearing if faulty can cause shifting problems like cant get into gear and/or slipping out of gear.
If you bought the car @ 105K and your at 135K now and have no idea about the clutch, it would be best to get the clutch replaced with a new one and that should solve the problem.
I recommend 5th clutch, havent heard a negative thing about it, only that people love it, and it grabs better than 4th gen oem.
Old Feb 21, 2005 | 12:02 PM
naptownryda's Avatar
i had that problem, it was the throw out bearing, i caught it early before major driving issues, had tranny rebuilt, still under warranty though,.....
Old Feb 23, 2005 | 05:41 AM
Zipp028's Avatar
Yeah, but i dont think the tranny would leak all fluid if i needed a clutch. Well if i need a new or rebuilt tranny i am prob going to get a flywheel and clutch since it is already apart.
Anyone know what could cause the transmission to not engage and leak the fluid?
Old Feb 23, 2005 | 09:22 AM
MDeezy's Avatar
I'd advise acting quickly think everything thru, but when I had discovered my tranny was leaking (which was 2 months after a new clutch install) the tranny leaked it fluid all into my brand new clutch which was soaking it up like a sponge causing slipping, so just a heads up.
it could leak from bad seals, bad bearing, worn down metal.
It could not engage due to low pressure in the line, throw out bearing, clutch grab point might need adjusting closer to the floor
some ideas
Old Feb 23, 2005 | 10:33 AM
Zipp028's Avatar
ah! found out what was wrong!! As I was driving my right drive axle broke and hit my transmission or pan (something) causing it to leak when i broke down. So i need a new front right drive axle and new braket and im guess a few other small parts.
Old Feb 23, 2005 | 10:36 AM
MDeezy's Avatar
raxles.com, I believe its $120 for passenger side axle.
Old Mar 1, 2005 | 12:28 PM
Nismo3112's Avatar
Custom User Title
EDIT
Hmm, I wonder how your axle just all of a sudden broke?
Old Mar 2, 2005 | 08:23 AM
jome80627's Avatar
this is the same thing I went through with my '97. I had 85k on it. One evening the noise got considerably louder. The next thing I knew, I couldn't even get the stick into 1st or 2nd. I took it to the shop this week and it's gonna run me about $1300 for the rebuild. The more people I talk to on here, the more it seems like a problem with the 4th gens.
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
