DooOood! How can I make my car stick?!!
Old Feb 22, 2005 | 03:32 AM
DaBombX's Avatar
Man...
I'm telling you...
I've got traction issues...
I need to do something about this...
It's really annoying.
I spin off the line.
I skid when I stop.
I understeer when I turn.
It's making the Audi's w/Q look really good...
But they're too much of a headache to maintain.
Can someone in lameman's terms tell me what I should be doin?
Maybe I should really start looking into changing my car?
But I'm sure you guys will convince me otherwise.
FYI.. stock 15's, auto, weak brakepads w/o abs, maxsprings on AGY's...
Oh, did I mention. You Orgers Rule... Again and again and again.
Old Feb 22, 2005 | 03:33 AM
DaBombX's Avatar
...plz don't say go slow... cuz I understand that part.
Old Feb 22, 2005 | 04:26 AM
mansurxk's Avatar
oh...well....then...just dont go so fast!
Old Feb 22, 2005 | 05:04 AM
mzmtg's Avatar
Minister of Silly Walks
Sounds like you are in dire need of new tires.
Old Feb 22, 2005 | 05:08 AM
bluevr6's Avatar
Ok, First things first. The only Quattro is the original coupe Quattro.
All the rest are just quattro:
First and foremost, check out your tires. Correct tire pressure. Good quality rubber, preferrable of the performance variety.
Good brake pads (I like Ferodo Street / Autocross compound and Hawk HPS+)
Flush brake fluid (use good brake fluid) The wife's maxima gets Valvoline Synthetic and both the S4 and the Bertone get Motul (flush it annually).
Analize the condition of your suspension (worn struts/shocks, strut bearings, tie rod ends, etc.) A good alignment shop can do this for you.
Recommendations.
Tires: Yokohama ES100's in 225/60/15 on OEM rims. 35PSI all around.
Brakes: Hawk HPS+ plus SS braided brake lines + speedbleeders + fresh fluid
SHocks / Struts: (as you car is a 96, it is probably due) AGX's (at same time, replace all strut bumpers and strut bearings.
Now, go out and practice threshold braking (most brakes applied without locking things up).
And practice your launches. With the 225/60/15's, traction should not be an issue.
Good luck,
Kevin
Old Feb 22, 2005 | 05:11 AM
mzmtg's Avatar
The stock tire size is 205/65-15. It's a 6 inch wide rim. 225/60 will give the wrong overall diameter and I wouldnt recommend running a 225 tire on a 6 inch rim.
He already has AGX adjustable struts and lowering springs, as he already posted.
Old Feb 22, 2005 | 05:16 AM
mzmtg's Avatar
Also, the Yoko ES100 isn't available in 225/60-15 anyway...
Old Feb 22, 2005 | 08:12 AM
MainSource's Avatar
Hit 'em with the stun gun
Recommendations.
Sorry for being a bit OT, but I was looking at getting some new brake hardware, Brembo crossdrilled/slotted rotors f&r, SS braided brake lines, and pads. I was looking at the HPS pads, but when I look at prices, it says "axle set", what does that mean? Thanks for the help.
Old Feb 22, 2005 | 08:39 AM
mzmtg's Avatar
When you see them priced "per axle" or whatever, that means that's the price for both left and right front or left and right rear. You'll get 4 pads.
Old Feb 22, 2005 | 08:54 AM
eturnl
my BFG's Traction T/A, are awesome on stock sawblades...
Old Feb 22, 2005 | 08:57 AM
Chickan's Avatar
Man...
I'm telling you...
I skid when I stop.
Its LAYMAN's terms, you are not lame (you can walk, right?).
As for traction, most of the wheel spin off the line is due to it being a FWD car, and you just have to get better at launching. Better tires = big plus. Also, next time buy a 5 speed, much more control over launches, and its more fun to drive.
Old Feb 22, 2005 | 09:29 AM
deezo's Avatar
It's not like he's boosted. Our cars aren't that bad on launches.
Old Feb 22, 2005 | 10:30 AM
Wetballoon's Avatar
Running Potenza RE950's on sawblades w/ a 5 spd. Only traction issues I ever see occur in the really wet. Sometimes I do break em loose just for fun, the kids love it.
Old Feb 22, 2005 | 10:33 AM
kbmaxima's Avatar
get new tires. and slow down! hehe yea don't run 225's on the sawblades. the dealership i bought it from put 225's on mine, and since im flat broke theres no way to replace them. Everytime I hit a bump, I go flying, so I have to correct it.
Old Feb 22, 2005 | 10:39 AM
Ceasars Chariot's Avatar
Old Maxima Legend
will have to spend some money on a wider rim/tire, a sticky tire, lsd, motor mounts, and fire out of the whole around 2-2.5k .. also check parking brake and make sure its not up ! lol
Old Feb 22, 2005 | 11:11 AM
deezo's Avatar
Yeah, our cars have enough torque to make that happen. I have them on my stock steelies and they're phenominal in the wet.
Old Feb 22, 2005 | 12:33 PM
bluevr6's Avatar
I have been running 225/60/15's on teh wife maxima on stock wheels for 5 years now. less than 1% difference in overall diameter of tire.
Also, the wider sidewall acts as a rim protector.
As for tires on rims, I have run 235's on a 4" wide wheel before.
Funny wear patterns, but boy is there some stick there.
Peace,
Kevin
Old Feb 22, 2005 | 12:35 PM
bluevr6's Avatar
That ain't the tires.....
Peace,
Kevin
Old Feb 22, 2005 | 08:33 PM
DaBombX's Avatar
what do motor mounts do to help?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
maxima-junky
Aug 13, 2015 09:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
