where is the speed sensor on a 96 maxima SE??
Old Feb 22, 2005 | 08:06 AM
96ItaliaSE's Avatar
il massimi bassi
odometer sticks......everything else is fine....speed sensor is only 20.40 from courtesy ....ill start there....one question where the heck is it?
Old Feb 22, 2005 | 08:41 AM
mzmtg's Avatar
Minister of Silly Walks
If your speedo is still working fine, I doubt the speed sensor is the problem.
Old Feb 22, 2005 | 08:52 AM
Chickan's Avatar
what do you mean by odometer sticks? Is it stuck stuck, or does it miss some miles here and there? Does your speedometer still work right? Does your tripometer work?
Old Feb 22, 2005 | 09:18 AM
96ItaliaSE's Avatar
il massimi bassi
Lately after a few miles it misses some miles here and there. speedo is good...tachometer fine....just odometer "sticks" ...dont wanna spend big $$ on a calibrated cluster
odometer and tripometer stick at same time
Old Feb 22, 2005 | 09:23 AM
mzmtg's Avatar
The speed sesnor is not going to help. You may want to open the cluster and blow out the odo mechanism with some compressed air.
Old Feb 22, 2005 | 09:25 AM
96ItaliaSE's Avatar
il massimi bassi
the more searching .........this seems more common than usual...... one guy tried air and the other soaked the cluster in some penetrating oil to no avail.....ebay looks scarce I dont wanna F* up my mileage any more...
where is the speedsensor anyway? its only 20.40 I can always try it
Old Feb 22, 2005 | 10:31 AM
Jepht20's Avatar
Custom User Title...
if you remove your stock intake up to the throttle body, and look down in that area just past the fuel filter, you'll see a thin white tube. that tube (which may be dirty from years of driving) connects the speed sensor to it's harness. it's not too hard to spot so just look down there and you'll find it.
however i don't think that sounds like your speed sensor, i'd get a new cluster and replace that part if i were you by swapping it. but that's your call...
Old Feb 22, 2005 | 10:43 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
dont waste your money on a new speed sensor cus thats not gonna fix anything. go to nissan and buy a speedo head for your cluster.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
niZ
Aug 7, 2015 10:18 PM
