cleaned TB and added restore
just got done cleaning my TB and was wondering how everyone else did it. i just sprayed TB cleaner and took lintless shop towels and wiped all the carbon crap out i could. i kept spraying until it was all clean coming out and had no more carbon in it. anyone else do the same or something different?
i also added that engine restore crap....just tried it out and gonna wait and see. it said i would see an improvement by 500 miles so ill wait and see then. anyone else use this stuff? thanks
i never belive in that crap adding to you your car newer works is like put some greese on your hands and try to rinse them with water you need put some on them and really scrub it of same thing with those addons to your car if you really want to clean some thing out you have to take it off and clean for real
just my 5 cents
just my 5 cents
just my 5 cents
just my 5 cents
huh???????
Originally Posted by RockinTheDecks
huh???????
Originally Posted by kbmaxima
exactly what i said. the weirdest is the whole 5 cents thing. anyway. i believe in chevron techron for cleanin out the fuel system. Got about 60 more miles to the tank, and thats even under hard driving. Seafoam has it's own controversial section. Give Chevron techron a try, if it can't help, it can't hurt either.
not necessarily true
just my 5 cents
just my 5 cents
english dude....puncuation...seriously
Why did you put Restore in your maxima? Does your engine have high miles with low compression readings?
The Maxima engine is one of the best built car engines in the world. I have Maxima's with 200,000+ miles that do not burn any oil or have any blowby problems. If your engine has normal compression readings, no need to use Restore.
I tryed to clean my throttle body....yeah...jeeps are so much easier...there are like 59379327 hoses connected to my throttle body, I couldnt get one of them off which kept me from taking it out...and another hose started dripping green shiz..(antifreez?)....but hey, its cleaner now then it was b4.
No need to worry here, it shouldn't do any harm , but just to be on the safe side - go and change your oil tomorrow !!!
I drove 95 max 5 speed with 365K on it, the engine run perfect and it didn't need any additives.
Nick.
Nick.
Originally Posted by Irishmax99
110000 on a 99
Nick.
Nick.
365K, and me and Pat dropped it on wepon r coilovers !!!
Nick.
Nick.
Originally Posted by JClaw
365,000 !??!? That's almost as ridiculous as that classic SE-R with 451,000 on the clock.
Former Sponsor
I cleaned my TB yesterday and now I have a "Engine service soon" Light on! I don't know what I did wrong, I disconected the battery , then this morning when I conected the batery the light still there!
Originally Posted by Crockpot
take off the entire air intake system....
takes like 2 secs if u just look for where its all connected to car
Take the entire throttlebody off. Spray some carb cleaner in there and scrub thoroughly. This still will not get everything around the butterfly valve off. You need to take either the green part of a dishwashing sponge or very fine grit sandpapaer and scrub the throttle body with it. This is the only way to get the throttle body back to factory condition, especially with many miles on the car.
Also, you all may want to be checking out SeaFoam for engine cleaning. There are three applications: crankcase (oil), gas tank, and the intake manifold.
You all need to understand though, by cleaning the throttle body, which is about a tenth of the intake system, you MAY notice better response and idle, but def. no horsepower releases. The bes bet is a port and polish, which can be cheap if your cover is already over.
Also, I never threw any codes after doing all of the above stated.
Former Sponsor
I used my old teeth brush to clean inside the TB , Also I cleaned the TB'S from my brother's Z and the Check engine light didn't turn on
Former Sponsor
Originally Posted by maxjetblack
btw is this at the shops from autozone? or the actual store?
