Stupid Check Engine Light Question
OK - Feel a little dumb asking this but...
I know how to check the codes thru the ECM, but I work around the corner from an Autozone... but for the life of me I can't find the OBD II connector!
Help!!!
Thanx in advance!
Help!!!
Thanx in advance!
On the 95 Maximas the OBDII connector is on top of the tunnel on the passenger side of the compartment. It sets on top of the ECM. The connector at the fuse panel is for the Dealer's version Scan Tool. I use a ScanTool.net ISO scantool and my notebook computer to check out our 95 Max and my GF's daughter's 95 Max 5 spd.
Actually had the entire car looked at and well there are a couple of more items that need work
both front wheel bearings (had an idea/squeal that 1 or both were going)
shocks/struts (knew they were going but wanted to deny it)
starter
muffler (the bottom is totally rusted out, if it wasn't on a lift...)
alignment
the work to clear the Code
and an inspection
Any clue how much this is going to set me back? I am hoping under $1500 or is that just a pipe dream?
starter
alignment
and an inspection
doobadoo
Aug 15, 2015 06:43 PM
bassmann
Aug 3, 2015 07:53 PM
