Loud squeeling noise...just replaced belts
Old Feb 23, 2005 | 01:56 PM
jtm087's Avatar
Just this weekend I replaced my water pump and since I had to take the fairly old drivebelts off, I decided to replace them. Now every time I start my car up there's a loud squeeling noise that doesn't stop and get louder as you rev the engine up... I've been adjusting the tension for the past 2 days with no luck.. took it to merchants and the guy said, it could be the pulley or the tensioner because it wasn't tensioning corrctly. So I go to the nissan dealership and pay $80 for a new pulley tensioner, and work on tighening/loosening it all day with no luck.... Sometimes the car would start up and run for about 5 mins fine, but then start squeeking.. what could be the problem???
Old Feb 23, 2005 | 04:45 PM
big_al's Avatar
Did you loosen the nut on the idler pulley first?
Old Feb 23, 2005 | 07:46 PM
jtm087's Avatar
sure did, that part was a b!+ch cause the space is so small and my wrench was mad short
Old Feb 23, 2005 | 08:11 PM
naijai's Avatar
replace idler pulley had the same problem after i changed belts and yep it went away
PH98I30
29
Feb 10, 2025 12:03 PM
tsi6001
Oct 3, 2022 10:23 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
