Questions on front brakes
Old Feb 23, 2005 | 02:09 PM
Pronto's Avatar
Do the pistons just push into the calipers with a C clamp or do you need that tool to turn then in? Is it worth the $20 a side for a new pin kit? I got 63k miles on the car.
Old Feb 23, 2005 | 02:11 PM
Jeff92se's Avatar
I'm needing a caw
http://www1.autozone.com/servlet/UiB...Parameters=004
Old Feb 23, 2005 | 02:26 PM
SkoorbMax's Avatar
I don't know why you'd need new caliper slider pins. Just take the old ones out, clean the holes (with a q tip or something...or hell don't even bother cleaning them), regrease the pins, and that's that.
Front brakes take a large C-clamp (got mine at home depot). The twisting tool is for the rear.
Old Feb 23, 2005 | 02:40 PM
karguy's Avatar
Take the caliper pins out and check for wear. I did my brakes at 55K and I had to replace them in the front but the rears were fine. I bought my caliper pins at Advance Auto and they were $22 for 4 of them. As an aside the rear caliper pins are the same as the front ones. Might save you some time trying to find rear caliper pins if you ever needed them. It has been 18 months since I did my brakes with no noise or any other problems.
Old Feb 23, 2005 | 03:08 PM
JSniper0's Avatar
c-clamp, channel locks if ur strong enough
rbuswell
Nov 17, 2016 04:54 AM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Jcof88
Aug 3, 2015 10:43 PM
