keyless entry, radio and other stuff quit working
Old Feb 24, 2005 | 06:54 PM
motocross416's Avatar
For some reason the keyless entry, radio, clock and visor mirror lights quit working on my car. The climate control still turns on and works. I didn't see any fuses that looked blown. I have had the gauge cluster out though, I'm not sure if removing, then replacing it had anything to do with it? Any ideas as to what might be wrong? I have no idea.
Old Feb 24, 2005 | 07:00 PM
PAREDLINE's Avatar
You probably pinched a wire when you removed the gauge cluster.
Look under the hood at the fuses. I'm sure you blew one.
Old Feb 24, 2005 | 07:25 PM
Is there any particular fuse under the hood? I looked in the long skinny fuse box that has the ignition fuses and didn't see any blown in there.
Old Feb 24, 2005 | 07:28 PM
PAREDLINE's Avatar
Dont just look. Check them with a circuit tester. If you can spot a blown mini fuse just by sight then you have super vision
Old Feb 24, 2005 | 07:31 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Check the ELEC fuse that is in the interior fuse box. It is in the top right hand corner. I had that happen to me too and I just took it out and put it back and everything work again.
Old Feb 24, 2005 | 07:32 PM
2 Da Max's Avatar
your bcm probably
Old Feb 24, 2005 | 07:38 PM
what is the bcm?
Old Feb 24, 2005 | 07:43 PM
maxima_kenny96's Avatar
im sure u pinched a wire or sumtin along the way, i cant think of any other reason it would just STOP.
Old Feb 27, 2005 | 02:39 PM
I fixed it!! I couldn't figure it out, I was going through all the fuses seeing if any were blown, and I didn't see the top fuse (#40 I don't know the name but it is a 7.5A fuse) until I pulled the bottom of the dash off to change a gauge cluster light. That fuse is so far up there, I didn't see it. I didn't have any spare 7.5A fuses, so I put in a 10A one for now.
Old Feb 27, 2005 | 02:42 PM
2 Da Max's Avatar
NOO never put a higher ampere than what is recommended. i mean a 8 is ok not a 10. btw that was the electrical parts fuse Iiliac mentioned. btw i like your max very clean
Old Feb 27, 2005 | 02:50 PM
I will put in the correct fuse when I can get into town. I think it should be alright for a little while. After I bought my car I found a bare wire stuffed in a blown ignition fuse under my hood. It basically eliminated any fuse and I ran the car with that for about 5 months before noticing it. And thanks, it WAS a nice car. check out my cardomain
Old Feb 27, 2005 | 02:57 PM
joosdawg's Avatar
speaking of which is there a fuse somwhere just for keyless cause mine went out and its annoying sense i just bought the fob and replaced the battery but that wasent it
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
