Making the doors close smoother
Old Feb 25, 2005 | 10:51 AM
Kehops's Avatar
My driver's side door has become very clunky when closing it. Is there anyway to replace the door jams? I'm not quite sure what they're called but those rubber covered springs that catch the door when your close it, would changing these make the door close nice and smooth again?
Old Feb 25, 2005 | 11:38 AM
Kehops's Avatar
...Anyone?
Old Feb 25, 2005 | 11:43 AM
erty67's Avatar
Decal Specialist
if I had to guess, maybe you need new door pins. ie: the pin that is in the door hinge. I've never seen this being a problem in maximas, but it is a common problem with cars that have heavy doors. (camaros, mustangs, and many other 2-door cars) the bushing on the pin get worn and the door sags.
Old Feb 25, 2005 | 11:58 AM
Chickan's Avatar
see if your door is dragging/hitting on the bottom panel, if it is, then I second what erty67 said. If its hitting badly, you can just beat the panel down if it is knocked up - its what I did on my '90 300zx.
sunten1
or maybe there hard to close becuase the car is cold...i would just wait till summer and seee if that still happens....ohh ya and maybe you should have sprayed some wd 40
Old Feb 25, 2005 | 02:43 PM
Black Maxima
WD 40 doesn't help lubricate the doors. You need to use a silicone spray. You might just need to lubricate the hinges.
Old Feb 25, 2005 | 02:44 PM
maxima_kenny96's Avatar
Lub it and it should work better, if not, get new hinge insert things. I dunno what to call them
Old Feb 25, 2005 | 02:46 PM
Jepht20's Avatar
Custom User Title...
there is a part supposedly that can be replaced that will fix your problem. i remember a thread about it a while ago. i'll see if i can dig it up if no one else remembers. try calling the dealer because i'm sure they'll know what needs to be replaced.
Old Feb 25, 2005 | 03:14 PM
Jepht20's Avatar
found this when searching:
Originally Posted by njmodi
Here is some info from the MAXFAQs regarding this problem:
Q: The door hinges on my 4th generation Maxima seem to bind and squeak. Is there a fix?
A: YES! Here's some information from George:
The "Link-Door Stopp", PN# 80430-51U01 is what needed to be replaced when my front doors started "binding". They also called it a door stay on the work order. Nissan calls the part a "countermeasure part". Replaced under warranty. The rear doors had the new type part already.
captchaos
Mar 15, 2016 12:18 PM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
Hailstatejig
Sep 2, 2015 06:52 AM
