Headlight Plug
Old Feb 27, 2005 | 08:18 PM
T-One's Avatar
Headlight Plug
I thought my Sylvania Super Blues (65/45 watts) had burned-out. When I went to remove the bulb, I moved the connecting plug and the light came on. When I removed the plug, I noticed it was smoking. Part of the female socket was starting to melt.
Can someone tell me what caused this? The stock lights were also 65/45 watts.
Old Feb 27, 2005 | 10:54 PM
bullfrog's Avatar
just a guess, but maybe you touched the bulb. i know you aren't supposed to touch the bulbs.
Old Feb 27, 2005 | 10:59 PM
MIXMAX's Avatar
touching the bulb causes it to break. the oils on your hand cause uneven heat displacement over the bulb. usually bursts or will cause gas to escape at base. could have been a bad connection when you hooked them up or maybe a defective bulb?
Old Feb 28, 2005 | 05:46 PM
T-One's Avatar
Found Problem
I didn't touch the bulb. The problem was with the connection. Make sure guys have a snug fit with the plug when replacing bulbs. A loose plug makes for a bad ground. The loose connection caused the ground wire pin to heat up and started to melt the plastic. I have to get new plugs and ensure a snug fit.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
