Clearance lights not working....?
Old Mar 1, 2005 | 12:01 PM
CheshireCat76's Avatar
My clearance/parking lights are not turning on.
All my other lights work. Heads, fogs, signals etc.
Anyone have an idea?
Old Mar 1, 2005 | 12:07 PM
Assassinroon's Avatar
same problem !
Old Mar 1, 2005 | 12:15 PM
Batxel's Avatar
blah
Fuse is probably blown.
15A in engine bay labeled as tail
7.5A in dash board fuse box labeled as tail
Old Mar 1, 2005 | 12:34 PM
96white's Avatar
check the 7.5 fuse. Its #5 in the box by your left knee as you are sitting in the car. Had same problem a few weeks back.
If your not sure where 5 is, its the far left row, 5th one up.
Old Mar 1, 2005 | 02:33 PM
hey i checked both of those fuses it workes fine then dies out on me later on. Does it haev anythign to do with the power im pushing ? I haev 2 12 inch subs on a amp and then another map for the interior spekaers
Old Mar 1, 2005 | 03:38 PM
Update
put in fresh fuses everything worked fine went to the grocery store came back home and 7.5 tailight fuse is blown
Old Mar 1, 2005 | 03:44 PM
Batxel's Avatar
blah
I have blown both fuses, but it occured when I took ricing to the next limit and went back to the stock bulbs and put green gel covers to support the home team for a week. My 7.5A fuse blew after about 3 hours of running them. I originally had Sylvania Silverstar amber bulbs in their which didn't cause any problems. My 15A fuse was blown because I screwed up a bit when installing my alarm/remote start system. So I've replaced them both. When I did the green thing I upgraded both fuses, I put a 10A replacement for the 7.5A and a 20A replacement for the 15. I now have switched everything back since they lost. I think somebody was telling me something.
You may have a short if it keeps blowing. You can draw more current than a fuse is rated for they usually will blow out over a certain period of time depending on how far over the "limit" your pushing it.
Old Mar 1, 2005 | 06:05 PM
how do i fix this problem ?
Old Mar 2, 2005 | 08:44 AM
OK thanks.
I'll check those fuses out.
Old Mar 2, 2005 | 11:05 AM
so should i just upgrade the fuses to bigger size fuses because mine keep blowing ?
Old Mar 2, 2005 | 11:10 AM
Nick7455's Avatar
No.....My fog lights fuse kept blowing out so I just messed with the grounding wire and made sure everything was secure. I would just keep messing with it.
Old Mar 2, 2005 | 12:21 PM
grounding wires to the clearance lights ?? im not sure what u mean
Old Mar 2, 2005 | 04:43 PM
bump
10 char
Old Mar 2, 2005 | 07:03 PM
Nick7455's Avatar
I don't think there are grounding wires for the clearance lights but what I meant was check the wires and make sure none are loose and all that fun stuff.
Old Mar 4, 2005 | 01:42 PM
hey yall its still doing it can u think of any other problems?
Old Mar 5, 2005 | 07:38 AM
Changed the fuse...lights are working. Thanks.
lowpost99
Oct 26, 2025 06:53 PM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
