Help!!!!!
Old Mar 1, 2005 | 08:30 PM
CKOTuHA's Avatar
Help!!!!!
I hit a curb in my car on high speeds. I didn't hit it straight, but scratched my front right wheel (3 spokes on SE rims). Now when I drive on the highway, it makes a sound like a wheel bearing, but not loud and not constant. Its the same as clock but in a very fast way, i guess with every turn of the wheel.
My alignment is off, have to keep my wheel almost 1/3 of the way to the left to keep the car straight.
Also, my front wheel stands weird, the bottom of it is more inside while the top is sticking out. Just like this "\" but not to this extreme.
When my mechanic lifted a car and put it on drive, my wheel was spinning and making a small 8 just like on the bike.
He told me that my strut is bent by like .25 of an inch, and it makes the tire off by like almost 2 inches.
Oh yeah, he put that rim with tire on the balancing machine and it was spining straight. So its not a bent rim.
Could that be a strut?
Old Mar 1, 2005 | 08:37 PM
bigbob's Avatar
oh ya the weakest part when hit by the side
Old Mar 1, 2005 | 08:42 PM
MDeezy's Avatar
Sorry to hear about the accident. Check out all the other suspension components and make sure those arent damages as well, if its just your strut then sounds like lowering time
Old Mar 1, 2005 | 08:53 PM
CKOTuHA's Avatar
Yeah, I was looking to lower this spring anyways. I'm going for Illuminas and H&Rs, but I just don't want any surprises.
Would those be the actual effects if a strut was bent slightly?
The ride of the car itself didn't change.
Old Mar 1, 2005 | 08:57 PM
2 Da Max's Avatar
check your control arms bro
Old Mar 1, 2005 | 09:03 PM
sryth's Avatar
Check everything in the wheel well: Control arm, strut, steering knuckle, tie-rod...see what's bent.
If you raise that side and spin the wheel it wobbles? If so, it's not just the strut that's bent.
Old Mar 1, 2005 | 09:10 PM
CKOTuHA's Avatar
Yes it wobbles. We have cheked the rim and its not bent.
Mechanic thought it was a control arm, but then he looked at it and said no.
Nothing else looked like it was bent. Actually strut didn't look bent to me either so I don't know.
Old Mar 1, 2005 | 09:11 PM
MDeezy's Avatar
get a 2nd opinion
Old Mar 1, 2005 | 09:58 PM
CKOTuHA's Avatar
I would but every opinion is money Because you have to take a wheel off and so on.
I just wanted to know if a bent or bad strut could have effects like mine? Maybe somebody dealt with the same problem before.
Old Mar 2, 2005 | 01:06 AM
sryth's Avatar
The strut shouldn't make the wheel wobble when it spins freely. Maybe your hub is screwed. Is there any play in the wheel when it's jacked up? Secure the vehicle and try pushing and pulling on the wheel.
Old Mar 2, 2005 | 01:24 AM
Kazao's Avatar
man Im sorry to hear about that, I really hated when these things happen.
