WTF My Max is GHEY
Old Mar 2, 2005 | 12:05 PM
Black Maxima
WTF My Max is GHEY
Hello, I was at full throttle, pedal pressed all the way, going up a long, fairly steep hill today. I do not know what speed I was at. Couldn't of been more than 70. All of a sudden the engine like bogged down and the tachometer dropped. I stepped on the pedal again after about 2 seconds and it seemed normal as I accelerated. I was like "WTF, this thing is a piece." to my friend in the passenger seat. I felt like a phagget.
I got up to speed without shifting gears with my Automatic, manually. And Overdrive was ON.
Was I just experiencing the "Speed Limiter" on my GXE? But, I thought that was only at 120 mph.
Okay, okay I will never ra...I mean speed again...
Thanks...Aaron
Old Mar 2, 2005 | 12:10 PM
brad kay
i experience similar things.. if i'm going like 70 and put the pedal to the floor sometimes it waits for a long time.. then the rpms drop really low and then jump really high. I think my auto tranny is telling me its starting to bite it, i think you might be experiencing the same thing.
Jeff92se's Avatar
I'm needing a caw
I could never state that. It's scary that you can.
.Aaron
Old Mar 2, 2005 | 12:13 PM
|Bijan|'s Avatar
UCF Lexus
what.........the hell
Old Mar 2, 2005 | 12:15 PM
konak85's Avatar
I think its cause the 4th gen auto has a really high 4th gear. You probably shifted into fourth. Try the same thing with the OD off(disables 4th gear).
Old Mar 2, 2005 | 12:17 PM
eckohb's Avatar
or maybe you had low gas, and going up the hill caused that problem. when i was low on gas, and the light was on, i was trying to make it to the gas station, and the same symptoms occurred.
Old Mar 2, 2005 | 12:23 PM
A Flood99's Avatar
this thread is worthless, but bijan....you get out of your tank trap?
Old Mar 2, 2005 | 12:50 PM
Black Maxima
HAHAHA, I was joking.
Wow your right. I was low on gas. My light wasn't on, but I think it's out. That probably was it. I went to the gas station right after. I'll have to try it again tomorrow and with OD OFF. It was just weird.
I know, but I'm having a bad day...
Aaron
Old Mar 2, 2005 | 12:51 PM
Black Maxima
Thanks guys!
Old Mar 2, 2005 | 12:54 PM
A Flood99's Avatar
Aaron
yeah i had one of those yesterday
Old Mar 3, 2005 | 10:15 PM
s0ber's Avatar
on the gas thing.
Old Mar 4, 2005 | 05:48 AM
SMX95's Avatar
Get a 5-speed problem solved..
Old Mar 4, 2005 | 08:30 AM
vortechpower's Avatar
: he got out. Oh I wish you could have seen the whole thing. So funny at the same time I never seen anything like it (how it got there)
Old Mar 4, 2005 | 08:45 AM
JetBlackMax83's Avatar
Moments like that deff require a digital camcorder!!!!! + a thread on the .org with links would have been nice NICE THINKING JEEZ Saving all the fun for yourself's that aint right j/k
Old Mar 4, 2005 | 08:46 AM
Armelius's Avatar
What octane were you running? 85 would do it. England had a gas called two star (out of four) so cheap. Put it in the Micra and the thing wouldn't go past 60 miles an hour with it, downhill even.
Old Mar 4, 2005 | 12:32 PM
MaxKlinger's Avatar
Your post doesn't make a whole lot of sense. You already had your foot to the floor, then you stepped on the pedal again? That implies you let off at some point...when did you let off? If you let off from WOT she's definetly going to try to shift into 4th (O/D) at those speeds (above 72mph, only 3rd and 4th are available). I don't quite understand what happened and what the problem is. My GXE Automatic has never had a problem bogging on hills. Please provide a better description.
Old Mar 4, 2005 | 12:56 PM
Black Maxima
Oh how I wish.
MaxKlinger - Yes I did let off after the rpms lowered.
I do think it was the gas in the tank. I was pretty low on gas.
Running with 93 octane.
Old Mar 4, 2005 | 01:35 PM
2 Da Max's Avatar
yea you were low on gas and all the fuel went to the back of the tank as you were going up the hill? :scratchy:
Old Mar 4, 2005 | 02:11 PM
Black Maxima
That's what I'm thinking.
Old Mar 4, 2005 | 02:22 PM
RockfordMax's Avatar
Back from the dead
I dont think. but if i did i would think that it tried to shift under too much of a load and couldnt do it. But knowing less than nothing about auto trannys who knows if thats even possible. Im Ron Burgundy?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
