Planned on installing my Y Pipe Today
Old Mar 4, 2005 | 12:01 PM
Zeus97MAX's Avatar
And planning on doing it was as far as I got. When I put the car up on a lift to start taking the exhaust apart, I couldn't get the two bolts on the cat converter to budge. The one bolt is so corroded that it doesnt even fit in the 14mm socket. I am going to have to break down and take the car to a shop and get them to torch the bolts off. Since i have my cat back on the way, I am going to probably just wait the extra couple of days, and get everything installed in one shot.
Old Mar 4, 2005 | 12:38 PM
ewuzh's Avatar
What you do is you should spray the bolts with a generous amount of Liquid Wrench. Then the bolts will come off with much less effort. This is what I did to get them off when I was installing my y-pipe. Good luck!
Old Mar 4, 2005 | 01:40 PM
2 Da Max's Avatar
get PB blaster spray it on and let it stay for 15mins. then you good, if not torch the bich
Old Mar 4, 2005 | 05:24 PM
DrTySOUFMaX23's Avatar
wd-40!!!!!
Old Mar 4, 2005 | 05:26 PM
Sky_99's Avatar
PB blaster the night before if possible. Then again 20-30 min before doing the job. If that doesn't work, go for a short ride to warm everything up a bit, and it should come off easy.
I'll be installing mine whenever it decides to stop snowing.
Old Mar 4, 2005 | 06:12 PM
joosdawg's Avatar
well if its super coroded like mine was they either brake off or round off either case i cut my stocker off
Old Mar 4, 2005 | 06:50 PM
Zeus97MAX's Avatar
I am probably going to just cut everything off, and replace the bolts. The corrosion is horrible, but since I will be replacing all of the equipment at once, I am just going to buy all of the new hardware and replace it all. I can't wait to eget out of the northeast!
Old Mar 4, 2005 | 08:33 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
i cut mine off too. just get a little diamond saw grinder and slice thoes ***** off.
Old Mar 4, 2005 | 08:37 PM
mansurxk's Avatar
shop time, not worth the frustration. i paid $15 bucks to get the bolts torched and did the rest myself.
JRod28
Dec 29, 2023 09:56 PM
VQ'ed
69
Aug 27, 2020 12:29 PM
Cotozic
Jun 28, 2017 08:01 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Trin1j23
Aug 12, 2015 08:31 PM
