Cat or no Cat
Old May 3, 2001 | 01:59 PM
Nismo's Avatar
does a high flow Cat really make a difference?? is it worth getting? would there be any sound difference??
Old May 3, 2001 | 02:20 PM
Dan 93 SE's Avatar
Mods
As much as I would love to sell you a Carsound Cat., you will definetly get more gains with a y-pipe. Gains over stock will not be that much, even with a high flow cat. Look at your own cat, compare to an RT or Carsound. There's not alot of difference, Maxima Cats are already pretty high flow. I would only consider replacement if I had 75K or more on the stock one. My guess is that a high flow cat probably won't be much difference than your OE set up.Hope this helps.
Dan WSP
Old May 3, 2001 | 07:55 PM
sx7r's Avatar
punch out your cat, it's free... unless you're a tree hugger, then nevermind.
Old May 4, 2001 | 07:48 AM
MardiGrasMax's Avatar
Old May 4, 2001 | 09:28 AM
Cumalot's Avatar
How hard is it to do that? If it's not that hard, I would like to do it to mine, instead of getting a test pipe, this is free. And let me get this straight, so I literally take my fist and punch the thing out? j/k
Old May 4, 2001 | 10:57 AM
fivelitrekiller's Avatar
Hey Cumalot, this is what I did to my cat...exactly! I took a flat-headed screw driver and banged out the main honey-comb filter within the cat. Then, once the inner part was gone, I took that same screw driver and banged out all the excess filter around the edges.....VOILA, no more converter.
cheers,
G
Old May 4, 2001 | 11:48 AM
cheers,
G
I did this on my VW Scirocco. I found that due to the large hollow chamber their is an echo or somthing that sounds weird. I wraped my straight pipe with two layers of exhaust wrap and I get no noise at all. Plus, if they ever do get serious about inspections in Lousyana you will need to have the cat to re install.
maxinout93
Oct 31, 2015 02:04 AM
lrb6805
Sep 18, 2015 07:07 PM
Justin Kroll
Sep 2, 2015 11:06 AM
