Random Engine shut off (HELP!!!)
Old Mar 6, 2005 | 05:05 PM
bliss's Avatar
I am any first time maxima owner and just recently my car randomly cuts off when i come to a stop or sputters at take off and then at other times it works just fine can some one help
Old Mar 6, 2005 | 05:07 PM
PAREDLINE's Avatar
is your service engine soon light on? It could be a lot of things.
Does it cut off when you step on the gas? and what year is your car
Old Mar 6, 2005 | 05:11 PM
bliss's Avatar
Yea My Engine Light Is On But Some One Else Told Me Because I Have On An Intake And The Other Wire Is Not Attached That N=my Engine Light Will Stay On 95 Maxima
Old Mar 6, 2005 | 05:14 PM
PAREDLINE's Avatar
That might be why your engine runs like crap. That wire is for a MAF sensor. You're not supposed to bypass it.
Old Mar 6, 2005 | 05:16 PM
bliss's Avatar
At Maf Sensor There Are Two Wires One Plugs Into The Sensor Snd The Other Has No Where To Plug Into But At Other Points The Car Runs Perfectly Fine So Its Very Puzzling
Old Mar 6, 2005 | 06:57 PM
gold4thgen's Avatar
its defenitley ur maf sensor i recently had the same problem check that its not loose that all the hoses are tight and that the wire is connected i had the same problem untill i tighten the intake pipes to the maf and car runs like before.......
Old Mar 6, 2005 | 07:15 PM
MaxGordon7's Avatar
Do spark plugs, clean throttle body, fuel filter, clean PVC
Old Mar 6, 2005 | 07:18 PM
bliss's Avatar
I JUST DID THAT TODAY IT RAN FINE FOR ABOUT 3 HOURS OF RUNNING UP AND DOWN AND THEN STARTED MESSIN UP TONIGHT BUT I HAVE AN AFTERMARKET RACING INTAKE ON IT
Old Mar 6, 2005 | 07:21 PM
bliss's Avatar
DID THE SPARK PLUGS ALREADY...... HOW DO I CLEAN THE THROTTLE BODY AND PVC
Old Mar 6, 2005 | 08:20 PM
MaDMvD's Avatar
Sorry, but what's with people not knowing how to use proper puntuation? And as if that weren't bad enough, TYPING IN ALL CAPS AND GOING ON WITHOUT USING PUNCUATION IS EVEN MORE ANNOYING I MEAN REALLY IS IT THAT HARD TO USE A COMMA OR PERIOD EVERY ONCE IN A WHILE DAMN
DJLAX152
May 4, 2021 11:46 AM
captchaos
Mar 15, 2016 12:18 PM
EdRomo86
Sep 12, 2015 07:49 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
