heavier steering
Old Mar 7, 2005 | 12:49 PM
lshi0's Avatar
heavier steering
drove my car to work this morning, and steering became heavier and stiffer. Any major problem?
Old Mar 7, 2005 | 06:33 PM
lshi0's Avatar
bump bump..
Old Mar 7, 2005 | 06:50 PM
PTownMax's Avatar
I still miss the max
need to post more info...
anything frrl broken?
Old Mar 7, 2005 | 06:52 PM
A Flood99's Avatar
i'd guess it would be power steering related
Old Mar 7, 2005 | 06:55 PM
lshi0's Avatar
steering feels little stiffer than usual since yesterday, nothing is broken, do u guys think i should do a flush?
Old Mar 7, 2005 | 07:03 PM
Broaner's Avatar
2060lbs and falling...
Just remove the whole system. Its going to fxck up your entire car. OMG! Run for the hills.
Seriously, this is not enough info to go off of. What does it do at idle? What does it do at varioius RPM's? Is the resivoir full? Is it leaking? Is the belt tight?
In November, before I disconnected mine it would be harder when cold. This was due to the belt slipping because it wasn't warm. When warm the rubber grips the pulley's much better.
Old Mar 7, 2005 | 07:11 PM
lshi0's Avatar
i just filled up the reservior to max level this afernoon, dealership did a drive belts replacement 2 months ago, i just couldnt figure out whats wrong. It also feel the same when warm. Btw, my 96 has only 48k miles on it, need a rack replacement?
Old Mar 7, 2005 | 07:28 PM
konak85's Avatar
check your front tire pressure
Old Mar 7, 2005 | 08:28 PM
Broaner's Avatar
The recent belt replacement should make your first suspect culprit be a loose belt. New belts stretch.
Old Mar 7, 2005 | 08:49 PM
lshi0's Avatar
rpm jumps alittle bit at normal temp, does rpm have something to do with power steering?
Old Mar 7, 2005 | 08:53 PM
lshi0's Avatar
btw, where can i get that thing measuring steering wheel turning force?
Old Mar 8, 2005 | 06:34 PM
Broaner's Avatar
The RPM will jump when turning wheel at idle. This is because the IACV opens. The tool you are refering to is just a fancy fish scale.
Old Mar 8, 2005 | 07:26 PM
Nismotic's Avatar
Always sunny in philly
How does it feel? Is it slightly stiff to drive or does it feel that u lost all power steering? My power steering pump went bad a few months back...
Old Mar 8, 2005 | 07:59 PM
lshi0's Avatar
just alittle bit stiff, maybe weather getting warmer these days and drive belts need an adjustment?
Old Mar 8, 2005 | 08:17 PM
Broaner's Avatar
If it does turn out to be the pump I have one for $40 shipped.
Old Mar 8, 2005 | 08:19 PM
FormorAccordMan's Avatar
could it be the weather?
Old Mar 9, 2005 | 05:35 AM
adithius's Avatar
You could have a low tire pressure, Or your rack & pinion needs some lubrication.
Old Mar 9, 2005 | 04:27 PM
lshi0's Avatar
how do you lubricate rack?
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
