Stuck shifter
Old Mar 8, 2005 | 01:33 PM
flxman's Avatar
Stuck shifter
I spilled some Orange Fanta on the shifter gear box and it has become harder to move the shifter (although it is still movable but greater effort than usual is required). I cleaned up the spillage as best as I could but is there the possibility of some serious damage to the gear box if I don't get it looked at.
Thanks,
Felix
Old Mar 8, 2005 | 01:41 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
Is this auto or stick?
Old Mar 8, 2005 | 01:44 PM
flxman's Avatar
It's automatic, 98 Maxima SE
Old Mar 8, 2005 | 01:55 PM
MaDMvD's Avatar
"Want a Fanta, don't you want a, want a Fanta? Trouble on the road? Oh dear! Get a Fanta , get in gear! (HAHAHAHAHAHA!!! THE IRONY!)..."
Old Mar 8, 2005 | 02:06 PM
aspec0002's Avatar
i was thinking the same thing, madmvd.
ive never taken an automatic shift lever apart, but i would say maybe take it apart and clean it?
Old Mar 8, 2005 | 06:05 PM
HomerMAC's Avatar
Donating i30 Owner
how sticky can fanta be.. and if anything it dries up in a day or two.. i cant believe its causing the gears to be that sticky.... hmm hey you can do the auto shorter shifter mod while ur at it..
Old Jun 24, 2006 | 07:55 PM
Judas
Instead of taking the whol console apart, could you spray WD-40 down there?
I know that there are elec. connections down there...but just checking.
Old Jun 24, 2006 | 09:38 PM
unclpaule's Avatar
you might have shorted out the shift lock soleniod. either that or all the little rods in there related to that thing are gummed up. like they said try clean them guts inside up a little. really not that hard to take the shifter trim off. one screw by ashtray, one clip behind the ashtray(just pry on right side of it) and then pry on the sides of the trim between it and the vinyl. popping it up on one side of the trim. i had to remove my shift lock soleniod. no biggy
Old Jun 25, 2006 | 12:34 PM
i30ds's Avatar
Armed and Dangerous
I dont understand you spilled the **** on the shifter or the actual transmission? If you just spilled it on the shifter, then just take the trim off and and take the shifter apart and clean the **** up.
Old Jun 25, 2006 | 07:54 PM
InsneDrmr's Avatar
old thread
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
atriuum
Sep 28, 2015 01:19 PM
