Low Fuel Light - When does it come on?
Old Mar 9, 2005 | 09:35 AM
MPScan's Avatar
I just recently got my 97 SE, and really wonder if the low fuel light works.
I drove recently on a highway trip 445 miles, the red line was PAST the "E", and when I went to fillup, it took 16.7 gallons to fill the 18.5 tank...
...yet the low fuel light never came on? How can I verify that it is indeed working, short of running out of gas? When does your light come on?
Old Mar 9, 2005 | 09:41 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Should be when you have 1 gallon left. That's how it's been in past cars i've had. I don't know for sure in the max.
Old Mar 9, 2005 | 09:44 AM
NmexMAX's Avatar
dot dot dot ...
2-2.5, hence from your observation. I can confirm this in both my Maximas, 95 and 03
Old Mar 9, 2005 | 09:50 AM
Black95Se's Avatar
it comes on way past the E in mine. I believe you have about a gallon or 20 some miles when it comes on and stays on.
Ian
Old Mar 9, 2005 | 09:51 AM
NmexMAX's Avatar
dot dot dot ...
Bottom line, keep it above 1/4 and you should be okay ...
Old Mar 9, 2005 | 09:52 AM
Bobo's Avatar
I have driven the car down past when the light comes on a few times, but not recently. In equating litres back to US gallons (I live in British Columbia), I believe the light should come on right about where you filled up, possibly slightly after. I think there is about 7.0 litres left when the light comes on constantly on a level road. That equates to 1.85 US gallons, bringing your refill to: 18.5 - 1.85 = 16.65 US gallons. You put in 16.7 gallons.
If you really want to find out try bringing it down a little past where you filled up during this "experiment". The bottom line is you still had gas left as you can drive on E or below for quite some time on the highway. Don't run out of gas as it doesn't do much for your fuel injectors. However, I must admit I ran out of gas once and had no problems with the engine.
kjlouis
Nov 24, 2018 06:09 AM
Roymg
Sep 3, 2018 05:10 AM
cruce91
Sep 20, 2015 10:23 AM
Slamrod
Sep 3, 2015 07:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
