95 Max drop solenoid location--Transmission shifting hard
Old Mar 9, 2005 | 11:03 AM
tverner's Avatar
95 Max drop resistor location--Transmission shifting hard
I am almost positive my drop resistor has gone bad--my shifts on my 95 Max Auto are super hard, very symptomatic of someone who has shorted their drop resistor for this very purpose. At any rate, does anyone know where to locate the drop resistor on my 95 Max so I can replace it? Thanks.
Old Mar 9, 2005 | 11:31 AM
LowProfile's Avatar
it's bolted on to the front-driver strut wall.
The arrow is pointing to a harness, but that is the area you'll find the resistor.
Old Mar 9, 2005 | 02:11 PM
RA030726's Avatar
I'm nutty for Nissans
you can see it in this photo. same area as above but with an actual DR.
tverner's Avatar
Thanks for the rapid response and the picture, what a great help. Do you happen to know where I can buy a replacement resistor other than the dealer? Do you know the resistor values? Thanks again.
Old Mar 9, 2005 | 02:27 PM
bigbob's Avatar
11.2-12.8 ohms ,also make it is not shorting to the inner fender when it is bolted down
Old Mar 9, 2005 | 03:05 PM
mzmtg's Avatar
Minister of Silly Walks
It's 12 MEGA-Ohms, not 12 Ohms.
Old Mar 9, 2005 | 05:43 PM
tverner's Avatar
Nissan dealer wants $55 for the part, anyone know an alternative method of replacing the resistor? Would radio shack have a resitor with the same values? Has anyone else had their drop resistor fail before? Thanks.
Old Mar 9, 2005 | 07:17 PM
big_al's Avatar
Did your CEL come on? I now if you do the drop resistor mod the light comes on.
Old Mar 9, 2005 | 07:41 PM
G4nismo's Avatar
i have a WOT switch setup and everytime i hit WOT, the CEL appears. its really annoying and thought about removin the bulb but then other possible problems that could light the CEl wouldn't appear. so i just reset my ecu
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
