need help on tire pressure for 235/45/17
Old Mar 10, 2005 | 04:08 PM
maximariceboi's Avatar
hey guys, i need some help... i recently got 17x7 rims and added 235/45/17 tires on them..so hard to put on but anyways, i need to know how much PSI i should put on the tire thanks!
Old Mar 11, 2005 | 06:47 PM
Stuntin' 101's Avatar
i run 32 on mine.. same size
Old Mar 11, 2005 | 08:04 PM
michaelnyden's Avatar
this is a very touchy question, it all depends on what you want to do with your car...if you are all about handling...put more pressure in...I have the same size and I run 35 cold all the way around...make sure when you measure your pressures you are doing it off absolutely "cold" readings...the extra pressure makes the sidewalls stiffer for less "rollover" additionally, tire pressures affect contact patches, if you want straight line traction (for launching and such if you drag) you put in a lot less in front and more in the rear...32 all the way around is a good number, but I would experiment with a little more and see how you like it...certainly for street driving don't go any less...
Old Mar 11, 2005 | 08:58 PM
vortechpower's Avatar
I like around 44psi in the front and 37 in the rear. Same size tire, 8 inch wide Wheel.
Old Mar 12, 2005 | 10:49 AM
thanks for ur help =]
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
