0103 and 0304 ecu codes
Old Mar 10, 2005 | 08:45 PM
maxjetblack's Avatar
has anyone got 0103 and 0304 ecu code? if i replace the knock sensor, would the engine coolant temp sensor code go away? or do i need to replace both of them?
Old Mar 10, 2005 | 09:01 PM
PAREDLINE's Avatar
Do a computer reset or reset the check engine light and see if they both still come up.
Old Mar 10, 2005 | 11:35 PM
brad kay
i'm really starting to hate that 0304 code
Old Mar 10, 2005 | 11:48 PM
Jepht20's Avatar
Custom User Title...
if you replace the egtc the ks would most likely go away, but it's not a bad idea to replace it anyways as most people end up doing it. i have done both and am happy that i have. goodluck
Old Mar 11, 2005 | 08:07 AM
i tried to look for a write up for the replacing the ects, but i couldnt find it. can anyone tell me where it is located and a basic write up for it? or link me to a write up?
Old Mar 11, 2005 | 09:29 AM
motocross416's Avatar
The CTS is only about $25 at autozone, so its relatively cheap. The hose that comes out of the top of the radiator goes down toward the engine and there are two sensors in there. The CTS is the one closer to the firewall.
Here is a side shot of the two sensors the CTS is on the right and is also the shiner one. I think it is an 18 or 19mm socket that you need to get it out. Just unscrew it and put the new one in. Don't worry, no coollant will come out when you take the sensor out either.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
