Engine Stalls at low speed/stops
Old Mar 12, 2005 | 07:40 PM
mans's Avatar
SOS guys! my 97 maxima has stalling (frequent but inconsistently) when driving to a stop or at very low speed in traffic, and after engine has already warmed up. the check engine light also has been turning on (and off after some time), and the trouble code pointing to MAF.
i've brought the car to two shops but when they tested the MAF and circuit, the engine wasn't stalling. so when they tested the MAF, it was good. i just got a used MAF from a good recycler today. BUT, i still experienced engine stalling just after installing the 'new' MAF. my check engine light is off though. although it's possible that the MAF i got is also faulty, but i think that the possibility that the MAF isn't problem is rather greater.
i've read a thread mentioning similar engine stalling linked to TPS and how to adjust it if TPS is not faulty. is it possible that while trouble code points to MAF, the TPS is the one faulty or needs adjusting? i've also read a TSB on EGI harness breakage. is this also a possibility causing MAF circuit fault?
please help. THANKS!
Old Mar 12, 2005 | 08:28 PM
InsneDrmr's Avatar
Did you reset your ECU? After I installed my new MAF it didnt work until it was reset.
Old Mar 12, 2005 | 08:36 PM
kc10fish's Avatar
might be a bad vac. lk. too. ck your vac. lines and see
Old Mar 12, 2005 | 09:57 PM
maxima_kenny96's Avatar
raise the idle speed by using the idle speed control valve on ur throttle body.
Old Mar 13, 2005 | 06:35 AM
mans's Avatar
wow, thanks guys. i'll jump right away to my car to check on these.
Old Mar 13, 2005 | 07:31 AM
njmaxseltd's Avatar
Clean your throttle body.
Takes 10 minutes, costs 5 bucks for a can of cleaner. If that doesn't work, then start troubleshooting.
Mar 12, 2020 12:06 AM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
TheMafia
Sep 4, 2015 08:26 AM
