Anyone get dramatic results with there NEW knock sensor?
Old Mar 13, 2005 | 03:05 PM
Luvs2speed
hey guys...just getting some feedback on knock sensors...anybody amazed by there new knock sensors?...better feel to the car?...anyone feel lots more power or get much better gas mileage?...POST RESULTS PLEASE!!!..thanks
Old Mar 13, 2005 | 03:24 PM
lilonasis's Avatar
I just got mine changed the other day and I can definitly feel more power. It's too early to check the gas mileage though.
Old Mar 14, 2005 | 05:24 AM
dallas0593's Avatar
Def more power since i switched out my bad KS! The old one was cracked and the plastic was all melted. My mpg went from low teens to about 20 mpg big difference, and i didn't even go new , i went with a used one with 90,000 miles on it
Old Mar 14, 2005 | 08:23 AM
Luvs2speed
thats good stuff Dallas :-)
Old Mar 14, 2005 | 10:04 AM
SPiG's Avatar
SomePsychoGuy
Yes you will feel it.
Old Mar 14, 2005 | 10:15 AM
Zeus97MAX's Avatar
Yes I definitely could feel a difference. basically for me, I have an auto, and when i would accelerate under 3000 rpm, the car would normally drag, and the rpms wouldn't increase when you tried to accelerate. Now there is much better response when you hit the gas.
Old Mar 14, 2005 | 11:27 AM
tofor's Avatar
Kinda
Sorta, kinda, maybe... replaced last week and I *might* have a bit more pull <3K rpm but it could just be my imagination. Only replaced it because the resistance was far too high (see http://forums.maxima.org/showthread....86#post2393786 for test and replacement).
Old Mar 14, 2005 | 12:04 PM
illmortal's Avatar
Sweet thanks for the info bro, I was wondering myself if I needed to replace the KS anytime soon. The owner before me took good care of it though... atleast I think so..
Anyways thanks for the link, I'm going to check it out!
-illmortal
Old Mar 14, 2005 | 12:06 PM
Adrian112597's Avatar
Adrian
I felt a power difference and also the car idles smoother, but I did notice gas mileage went down.
Old Mar 14, 2005 | 12:44 PM
NmexMAX's Avatar
dot dot dot ...
Depending on how long your old one was bad, so you should feel it.
Old Mar 14, 2005 | 01:25 PM
Terran's Avatar
Why would it matter how long it was bad...I thought it went into safe mode pulling back timing immediately?
I definitely felt it...more than the y-pipe IMO.
Old Mar 14, 2005 | 01:36 PM
NmexMAX's Avatar
dot dot dot ...
It did, but if you are used to the timing being retarded and just forget you need one, you wont notice it until you replace it, then the car seems like it's brand new. I went 2 years with a dead/dying KS, and the day I cahnged it, felt tremendously different just because I was used to getting owned by stock celica gt's and civic si's and it becamse no big thing, now things are different. You're right it does go into safe mode, but if you're used to it and don't notice it, when you change it, the results will be far more appreciated.
Old Mar 14, 2005 | 02:08 PM
maximaintheface's Avatar
i dunno i can feel it a little but it doesnt seem to be much faster at all. but im not sure if it needs to adjust or somthing i dunno
Old Mar 14, 2005 | 02:23 PM
NmexMAX's Avatar
dot dot dot ...
Make sure you use 91+ fuel.
Old Mar 14, 2005 | 03:43 PM
brad kay
i felt it a LOT. with a bad knock sensor i couldnt even get my tires to do anything more than chirp.. even if i braked at a stop and revved to 1500+ rpms.. that sucked. Sooo much more pull down low in the rpms now
Old Mar 14, 2005 | 07:09 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
definitely felt a difference when I changed both the KS & the left front heated O2 sensor
Old Mar 14, 2005 | 09:44 PM
im starting to notice mine now for a while i thought it was not tight enough but it didnt throw a code oafter liek 100 miles or so and now its starting to pick up alot better
Old Mar 14, 2005 | 11:08 PM
Ant96GLE's Avatar
You will feel it... sort of. Its not a night and day difference like everyone says. I saw a whole lot of a bigger difference at the gas pump.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
