how do u remove the back seat?
Old Mar 13, 2005 | 05:49 PM
newdiamond's Avatar
i am installing sound deadening material in my Max and was thinking of a way to insulate behind the back seat...should I remove it or just insulate the inside of the trunk?
Old Mar 13, 2005 | 05:53 PM
Nismotic's Avatar
Always sunny in philly
To uninstall backseats are simple. Two clips at the base of the seat, 4 bolts at the corner, two in the middle
Old Mar 13, 2005 | 07:06 PM
Stuntin' 101's Avatar
mabye its different on the 97-99, but on the 95/6 its the two tabs you have to pull out under the bottom of the seat to release the clips, and then two 10mm screws on the bottom corners on the rear section.
if your installing sound deadening mat., whats the reason for doing it? is it just to quiet the ride in the cabin, or to benefit a stereo system? if you just want to quite the ride, id say go for doing behind the seat. if you have a system, i wouldnt do it. mabye just do the wheel wells behind the seat instead. the mat will also deaden your bass from traveling inside the cabin.
Old Mar 13, 2005 | 07:08 PM
maxima_kenny96's Avatar
check the stickies they have more specific DIY's but stuntin is right about how to get them undone. i got lost with his other explanation...only cause Im tired and didnt re read it
Old Mar 13, 2005 | 08:15 PM
newdiamond's Avatar
I am primarily doing it to deaden the road noise, with the added benefit of being able to enjoy the stock bose on the highway better, I've already done the doors and that has really helped...
Old Apr 16, 2011 | 11:21 AM
TheRandish's Avatar
Does anyone have a tutorial or write up about taking the back seat off? I am havin trouble finding all of the screws
Old Apr 16, 2011 | 11:52 AM
luke95gxe's Avatar
when you remove the bottom part of the back seat there are 2 10mm bolts on the corners then in the middle where the fold down part is there are 2 more ill get a few pics up for ya of the 2 in the middle
Old Apr 16, 2011 | 12:17 PM
Here you go:
http://www.vqpower.com/v2/articles.php?article_id=39
Old Apr 16, 2011 | 12:35 PM
TheRandish's Avatar
Thanks bro!
Old Apr 16, 2011 | 07:07 PM
Xfactor22's Avatar
no one realized that this thread is 6 years old?
Old Apr 16, 2011 | 09:31 PM
I did but I figured I'd help anyway.
Old Apr 16, 2011 | 10:27 PM
TheRandish's Avatar
I believe searching the forums for questions you have is what all the old timers preach, correct? well the question I had was asked but never answered so I "bumped" it, and in no time my it was.
Thank you.
JRod28
Dec 29, 2023 09:56 PM
doctorpullit
Aug 20, 2015 05:15 PM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
kirkhilles
Aug 8, 2015 10:53 AM
