p1335????
Old Mar 1, 2011 | 12:44 PM
sc10692's Avatar
p1335????
hey guys i have a 97 5spd that had trouble starting. i checked my ckps(ref) and it was bad so i replaced it and now my car is even harder to start and its throws p1335 as soon as i start up. any ideas?? thanks
Old Mar 1, 2011 | 04:08 PM
gen4maxrehab's Avatar
did you change them both or just one?
Old Mar 1, 2011 | 05:00 PM
Swazey's Avatar
http://forums.maxima.org/4th-generat...ere-first.html
Old Apr 15, 2011 | 08:11 PM
4thgenmaxnewbie's Avatar
p1335 code again
Hey guys, I'm new here, of course, but I had the p1335 code and I changed both sensors. I have hesitation from take off when the car warms up and @ cruising speed I feel like it is stalling. But when put to the floor it picks up to 130 easily. I went to Autozone and I got the same code along with tcm code, knock sensor code, o2 sensor, and p1605/0804 ( tcm signal com) I have no passing gear either. Any ideas? Oh yeah, noobie mistake, its a 96 if that helps.
Old Apr 16, 2011 | 05:35 AM
when was the last time it had new plugs, or a TB,IACV,EGR cleaning? also i did my sensors and it took over 200 miles to clear code and shut the light off, or clear them with the ecu trick and see what comes back
Old Apr 16, 2011 | 10:09 AM
p1335 code again
Thanks but I have already checked that link. Today I found a bad connector on my transmission and a blown a/t fuse. I fixed that and my transmission is pulling fine now. No more code for that. I also did the drop resistor mod and you guys were right , it is awesome. Thank you for this forum.
Old Apr 17, 2011 | 04:41 AM
Trini Boom's Avatar
Replace your starters people. If the starter is not cranking the engine fast enough, it will throw the P1335 code especially if you have a hard time starting. The sensor is within spec then replace the starter. Try to find an OEM starter...majority of those aftermarket ones are junk..
Patm-a32
Nov 18, 2015 05:23 AM
maxima297
Jul 17, 2015 04:59 PM
Patm-a32
Dec 28, 2013 04:38 PM
TrueKnight
Sep 23, 2011 06:23 AM
TrueKnight
24
Aug 9, 2009 01:04 AM
