Help, replaced EGR Valve, code still exists
Old Mar 14, 2005 | 10:26 AM
sb765t's Avatar
Folks,
Replaced the EGR valve last week, after an EGR code indicated flow issues.
Code cleared, light went off. Stayed off for a few days, then came back on. Same code.
Checked the Solenoid Control Valve for the EGR, and it test to spec.
What am I missing?
Thanks,
Evan
'99 SE, 87k miles
Old Mar 14, 2005 | 11:01 AM
knight71's Avatar
There was a thread here a couple of months ago, 99 max with same prob...here it is
http://forums.maxima.org/showthread....0&page=1&pp=30
also maybe this will help:
http://img52.photobucket.com/albums/v158/evilBIGD/EGR/
Old Mar 14, 2005 | 11:21 AM
Broaner's Avatar
2060lbs and falling...
Just pull it all off and save yourself the dough.
Old Mar 14, 2005 | 05:27 PM
joeeey's Avatar
I had heard of this in the past from a friend of mine who works at Star Nissan. He told me to clean the metal tubes for the EGR.
Old Mar 14, 2005 | 07:04 PM
WielkiWaac's Avatar
MaximaDriver
Yep thats true. Just clean that tube and u will be fine
Old Mar 14, 2005 | 07:55 PM
ultralighter's Avatar
I have to say I'm chasing the same problem and it turned out to be a bad EGR solenoid. HTH
Jim
Professional auto tech for 13 years.
Old Mar 14, 2005 | 08:02 PM
Bender-san's Avatar
Most of the hoses in the EGR system hold up pretty well over the years (unlike in the Sentras). I'd say that a flow issue is probably due to the EGR tube that bolts to the upper rear of the intake manifold. It's not the most fun to get out, but it's easy to clean with a pick and some carburator cleaner. If you've got access to a Consult tool, I'd test drive it after cleaning the tube and perform an active test on the EGR system. That way you don't have to wait 3 weeks for the system to test itself.
iflexsteel
Sep 15, 2015 03:37 AM
lowpost99
22
Sep 2, 2015 04:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
