Knock Sensor
Old Mar 14, 2005 | 03:41 PM
InsneDrmr's Avatar
Knock Sensor
My knock sensor code is still coming up. I decided to go out and try and test it but I cant seem to locate it with the info from the stickies. Anyone have a pic of where it is and what it looks like? It would be greatly appreciated. Thanks
Old Mar 14, 2005 | 04:06 PM
tavarish's Avatar
fwd gone rwd cr00
ok, it's very easy to spot, it's right in the "V" of the engine...it has a wire harness attached to it, and is held on to the engine by one bolt. there's a pic of it on the motorvate.ca site.
Old Mar 14, 2005 | 08:15 PM
Bender-san's Avatar
The code almost ALWAYS sets in 4g Maximas...even with a good sensor. Something Nissan never got right with the programming, I guess.
Old Mar 14, 2005 | 10:07 PM
NmexMAX's Avatar
dot dot dot ...
Mine has only thrown that code once in 5 years/140k miles.
Old Mar 14, 2005 | 10:56 PM
Ant96GLE's Avatar
Look at your intake manifold from the drivers side of the engine. You may have to move your stock intake to get a good look. It is located under the stock intake manifold in the V portion of the block between the 2 cylinder heads. Light it up with a flash light and you will see the sensor down there and a harness that leads to it.
www.motorvate.ca is your friend.
Old Apr 13, 2005 | 05:13 PM
shaun c's Avatar
my 95 threw the knock sensor code how do i tell if the sensor is really bad or just a bogus code. and if the sensor is bad, is there a certain brand to buy and what, if any mods should i throw on while i'm working on it.
Old Apr 14, 2005 | 06:24 PM
shaun c's Avatar
any help would be appreciated
Old Apr 14, 2005 | 06:30 PM
ThisMaxIsTight's Avatar
dude are you serious?....GO TO THE STICKIES...and then go to HOW TO's...scroll down a bit and the WHOLE thing is right there ...every bit of instruction for the KS
Old Apr 15, 2005 | 06:12 PM
shaun c's Avatar
ok maybe i was confused. when you guys say that your car threw the knock sensor code or that 4g's always throw the code, are you talking about using the self check with the ecu or using an actual diagnostic machine? bc i used the diagnostic comp. and got the ks code and a coolant sensor code. and i don't need any sarcastic remarks. as you can tell i'm new here and also new with my 4g max. thnks for the help
Old Apr 15, 2005 | 06:16 PM
Ms.Maxima™'s Avatar
This is the exact link with the pictures and how to replace it.
http://www.motorvate.ca/mvp.php/507
Old Apr 15, 2005 | 06:18 PM
MAXRB8's Avatar
The knock sensor doesn't bring on the CEL ( Check Engine Light) but does throw a retrievable code of ( 0304). To answer your previous question about where to buy? You'd be hard pressed beating this:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Also there are only factory KS's no after market. Good luck hope this helps
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
