Temperature Gauge is going crazy
Old Mar 15, 2005 | 02:22 PM
fredrock79's Avatar
I dont know why but the temp. gauge is going all the way to hot and goes back down, but the car is definetly not over heating. Could someone help me out here! Thanks.
Old Mar 15, 2005 | 02:23 PM
MaDMvD's Avatar
Has to be something to do with the sensor/thermometer, or the cluster. Since you have a '95, it might be the cluster. Make sure it really isn't overheating though.
Old Mar 15, 2005 | 02:30 PM
fredrock79's Avatar
yeah im pretty sure it not over heating, fan goes on. I even open the hood and everthing is ok. sometimes right at start up it goes up, guess Ill check the cluster. Thanks
Old Mar 15, 2005 | 02:48 PM
shadygrey's Avatar
Well my guage does the same thing and sometimes my climate control won't start the fan for heat. I have to do it manually. Where is the temp sensor located?
Old Mar 15, 2005 | 02:50 PM
JSniper0's Avatar
thermostat
Old Mar 15, 2005 | 03:00 PM
adithius's Avatar
If it happened to me, I'd change the sensor. It's only $25 and easy to do. See if that works.
Old Mar 15, 2005 | 04:40 PM
Jepht20's Avatar
Custom User Title...
mine has done it a few times too. i changed the thermostat about 3 months ago or so and changed the ectc a while ago, so i'm hoping it's the gauge itself. i have a spare so i'm gonna swap it when i put in my gauge rings and hopefully it'll fix it. as long as your car isn't overheating i wouldn't worry too much, unless it does it all the time which would be annoying but probably not be dangerous.
Old Mar 15, 2005 | 05:04 PM
ny96max's Avatar
my temp gauge flickers up and down like crazy for about 5-10 min but stops once my car is at normal temp
Ant
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Oct 28, 2019 10:58 PM
Garrettz459
Sep 28, 2015 02:50 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
