Rough Idle and Stalling - 99 Max
Old Mar 18, 2005 | 12:48 PM
Djpic3's Avatar
Rough Idle and Stalling - NEED HELP PLEASE
Ok, I read through some other posts about similar problems but haven't been able to figure this out.
Facts:
I have a 1999 Max, 5spd, Cali spec.
101,000 Miles on it...
Original Coil Packs
Plugs 20K miles old.
O2 sensor code off and on for awhile, now the light never comes on.
Problem:
After the car warms up (few minutes after starting) it idle rough, up and down on the tach (300-700rpm) When I drive it runs fin, UNTIL i come to a stop and depress the clutch. This is when it stalls, 30-40% of the time. There are small putters from the exhuast, but nothing major. Power is fine, milage the same as always also....
PLEASE HELP!!
Thanks.
Old Mar 18, 2005 | 01:01 PM
erty67's Avatar
Decal Specialist
on a guess, i'd say coil packs. 99s are well known for their troubles.
Old Mar 18, 2005 | 01:16 PM
finny's Avatar
could also be mass air flow going bad, my car was acting similar and thats what the problem.
Old Mar 18, 2005 | 01:37 PM
Loe max's Avatar
Facts:
Original Coil Packs
Problem:
PLEASE HELP!!
Thanks.
You've mentioned coil packs in your post so I would assume you leaning towards the coils also To test which coil isn't firing, unplug each fuel injector connecter harness one at a time and see if your idle changes. If you pull on and it doesn't show a difference, more than likely its that coil that needs replacing. Coils aren't hard to replace, its just one step easier than changing a spark plug, although more costly.
Otherwise, get out the multimeter, pull back the rubber boot on the connection near the MAF, and check the voltage. A faulty MAF can also cause poor idle as well.
Old Mar 18, 2005 | 01:43 PM
Djpic3's Avatar
Thanks everyone for the suggestions I will check things out tommorow morning. Leo Max, Do you know what the MAF voltage should be??
Old Mar 18, 2005 | 01:48 PM
Maximakid17's Avatar
Yep same thing here you can get one at the junk yard 100 bucks...
Old Mar 18, 2005 | 01:55 PM
Loe max's Avatar
Thankfully, 95-99 MAF's are the same part #'s, so if it is your MAF, you could just find one from a junkyard off of any year (assuming its in good shape).
Specs:
Engine off -> -1.0volt
Engine idle at operating temperature -> 1.0-1.7volt/s
Engine at/near steady 2,500rpm -> 1.5-2.1volts
It should have a linear voltage rise on up. If it doesn't, check the power the ground circuits.
Old Mar 21, 2005 | 07:36 PM
Djpic3's Avatar
Thank you all for the help. I checked the injectors tonight and in the process discovered a LEAK IN THE INTAKE MANIFOLD GASKET!!!! Right behind the drivers side front injector. I'll be replacing this tommorow, anyone have a link to instructions???
Thanks again!
Old Mar 21, 2005 | 08:42 PM
erty67's Avatar
Decal Specialist
http://forums.maxima.org/showthread....ANIFOLD+GASKET
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
