for people familiar with the wiring in the trunk
Old Mar 22, 2005 | 04:32 PM
kbmaxima's Avatar
I would like to wire up a neon to the trunk light simply because I have a spare lying around and that tiny bulb cant light up much. I'd like to know how to get to the wiring behidn that plastic white dome cover. I already broke the clip off of it, and want to be careful when tryin to get to the wiring. Should I just stick a flathead in there and yank it off? Thanks
Old Mar 22, 2005 | 05:46 PM
RA030726's Avatar
I'm nutty for Nissans
what wires do you want to connect to exactly?
Old Mar 22, 2005 | 06:08 PM
kbmaxima's Avatar
I would basically like to replace the light that lights up the trunk area when it is opened with a neon bar i have lying around. Have it light up with the trunk open and turn off when closed. I'm pretty sure its a noob wiring job, but I just don't want to break anything, ie. round dome cover.
Old Mar 22, 2005 | 06:09 PM
Maxtank's Avatar
there should be 2 screws holding the bulb holder. Take it out and the harness will follow. there is a connector, you can cut and splice, or run the wires right into the harness
Old Mar 22, 2005 | 06:14 PM
kbmaxima's Avatar
thank u sir
Old Mar 22, 2005 | 06:26 PM
Maxtank's Avatar
I had 2 neons up there before.....they don't reflect as well as you think they might. Might have to go with a cold cathode.
02PearlSE
Feb 1, 2016 12:37 AM
doctorpullit
Dec 12, 2015 09:39 AM
Maximeltman
Sep 28, 2015 07:19 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
