another stall/cant' start, plz help
Old Mar 22, 2005 | 05:43 PM
mrgreek's Avatar
i havent driven my maxim since sunday night (today is tuesday night)...
today was pretty hot and tonight was pretty cold(just telling in case it makes a difference)
as i went to start the car, it wouldnt start...and by the sound...i could tell it wasnt the battery cause ive had that happen before...
i didnt know wat to do...and i knew pumping gas or watever was my only option, and last thing i heard and wat my dad would always tell me is never do it even if it works cause it hurts the car long term...
any1 know wat this can be a result of? my diagnostic code is for the absolute pressure sensor...but could it also be fuel filter or ks or os or something else?
any help is greatly appreciated
Old Mar 22, 2005 | 07:44 PM
mrgreek's Avatar
comon, som1 must know
Old Mar 22, 2005 | 07:50 PM
G4nismo's Avatar
check ur starter. give it a couple taps and then try to start it.
Old Mar 22, 2005 | 07:56 PM
mrgreek's Avatar
wat u mean? u mind if i pm u? (since ur giving me ideas on both my topics)
Old Mar 22, 2005 | 07:58 PM
larryseibel's Avatar
does it crank? if so its def not the starter.
Old Mar 22, 2005 | 08:01 PM
mrgreek's Avatar
i dont know wat u mean...i dont know the terminology lol...i can start the car right now if u want...wat should i look for when doing it?
Old Mar 22, 2005 | 08:04 PM
when you turn the key does the engine move? does it crank over but not fire up or when you turn the key does nothing happen?
Old Mar 22, 2005 | 08:11 PM
mrgreek's Avatar
well b4 i went to class...i started the car and nothing was happening,,,the noise was not the same as if u had a weak or dead battery...other than that i cant explain the niose...the engine move? as if rattle and stuff then 'not any different than the past'...
when i left class however i had no problems,,this has been going on for a while now
Old Mar 22, 2005 | 08:15 PM
G4nismo's Avatar
if thats the case, tap ur starter and eventually, buy a new one.
Old Mar 22, 2005 | 08:20 PM
G4nismo's Avatar
u mean there is no noise. this happened to me and all i heard was silence and me crying cause i thought i broke it and the starter click sound whtever.
ur starter should be located somewhere under the circled area.
Old Mar 22, 2005 | 08:23 PM
mrgreek's Avatar
thnx, if it happens to me tonight or tomorrow, i appreciate the help
and thnx for the pic,,,makes it so mch easier for peeps like me
Old Mar 22, 2005 | 08:25 PM
G4nismo's Avatar
just another thing cause ur a newb, ur car will start sometimes and sometimes it won't.
thats when u tap on the solenoid. but go to parks auto and buy a rebuilt one.
got mine for around $128 and installed it w/ a friend in under an hour.
Old Mar 22, 2005 | 08:27 PM
2 Da Max's Avatar
yes get it now before it gets completely dead, and just hope you wont be in a bad spot when it happens
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
