high idle
Go to http://members.dslextreme.com/users/maxima/esm/,
a32-ec.pdf page 35, there is a procedure how to adjust idle speed.
I doubt your idle screw is off if you have not screwed with it. I had a smiliar problem when I tightened my throttle cable....make sure the little peg on the bottom of....I don't know what to call it but the part where the cable hooks (cable holder), make sure that touches the metal when you are at idle. Also a vacuum leak will cause a high idle. Good luck.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
